How to Swap Interior Harness?
Hi,
I searched for a how to on swapping interior harnesses and checked the FAQ sections, but had no luck finding a thread. So how do I swap an interior harness on a 2000 ex. I swapped a 2000 HX motor in and I guess all HX's are obd2a so I need to swap the interior harness in to make it work. Thanks! |
Re: How to Swap Interior Harness?
take the old harness out.. put the new one in?
maybe more details would help your thread, year of car, make model.. year fo harness, make, model.. reason for changing. |
Originally Posted by b18cEK
(Post 39721695)
http://www.boomslang.us/obd2to2.htm http://www.evasivemotorsports.com/me...ode=OBDHARNESS Evasive has a much better price.. |
if you dont want to buy a conversion harness or if you have the HX underdash already, it really is as simple as pulling the dash, taking the old harness out, swapping in the new harness.. you might have to change some plugs, but just make your self a pigtail and then cut/solder/repeat.
For $62 off ebay, I may as well just get the conversion harness.
Thanks for the info guys! |
Easy and pulling the dash should never be in the same sentence.
Good deal man, good luck with your issue. |
yea your better off just going to your local import speed shop i getting an obd2a or b jumper harness for like $90-$120
then again its pretty easy pulling the dash.
i dont see why the 2000 HX would be obd2a! if anything, it probly has an obd2a harness on it, all you have to do is use your 2000 ex engine harness and you'll be set, no need to downgrade your interior harness!
Originally Posted by slowhatchcali
(Post 39736939)
(Post 39736939)
If you try to run and OBD2A Interior harness with an OBD2B engine harness you will be missing plug "A" at the ECU (this is because plug "A" is part of the engine harness on OBD2A civics and part of the interior harness on OBD2B civics) If you try to run an OBD2B interior harness with an OBD2A engine harness you will have problems as well. If it was anything but a '99 - '00 HX i'd just say modify the harness in it. Bit in this case I would replace the interior harness. Pulling the dash is not hard, a little time consuming the first time you do it, but not hard. |
Originally Posted by 94EG8
(Post 39741418)
I don't think anyone does, but the point is they are.
You can't run an OBD2A interior harness with an OBD2B engine harness or vice versa. If you try to run and OBD2A Interior harness with an OBD2B engine harness you will be missing plug "A" at the ECU (this is because plug "A" is part of the engine harness on OBD2A civics and part of the interior harness on OBD2B civics) If you try to run an OBD2B interior harness with an OBD2A engine harness you will have problems as well. If it was anything but a '99 - '00 HX i'd just say modify the harness in it. Bit in this case I would replace the interior harness. Pulling the dash is not hard, a little time consuming the first time you do it, but not hard. |
(Post 39748572)
no, you didnt understand what i was trying to tell him... i told him to use the 2000 EX harness, his car is 2000, will it match up? I think so. There is no need to replace the dash harness, that is way more work than what this is calling for. Get an obd2b harness, throw it on the motor, and bam! he's got himself a running car.
(Post 39748688)
Except that you forgot its an HX, leaving you with the EGR valve to wire in, rewiring for a 5 wire wideband O2 sensor, and a distributor plug to swap (or use a '99 - '00 Y7/Y8 distributor) Is it hard to modify the EX harness to do this? No, not particularly. Buts its definately no easier than just swapping the interior harness.
(Post 39748836)
id rather modify the ex harness than do an interior harness swap... have you ever done one? its tedious, and why downgrade the car...
Conclusion: -modifying the existing harness involves less physical work, but is easier to screw up if have never wired anything before. |
(Post 39750640)
As a matter of fact I have swapped interior harnesses before. Its time consuming if you've never pulled a dash and interior panels before. But otherwise its not that bad. I wouldn't really call it a downgrade. OBD2B didn't offer anything compelling over OBD2A. I've also modified more stock harnesses than most people on here (and did a better job than 99.9% of them too) The big reason I suggested the interior swap is that its very hard to screw up. Some people for whatever reason have a major problem with wiring (a lot more guys than you would think are color blind).
(Post 39750696)
about it being downgraded, depending on where he lives it might not pass inspection, CA at least is a bitch for us!
