How to reset ECU?
Re: How to reset ECU? (beatdown88hf)
u should lift up ur hood and look for the fuse box. take the ECU fuse out. and put it bak in and leave ur engine on for 10-15 mins so it can relearn everything.
Re: How to reset ECU? (Ignitecivic)
So I remember a few details sue me.
Re: How to reset ECU? (Spade)
couldn't you also just un hook the battery fo ra bit and then hook it back up... It's a chap solution but doesn't it work as well?
HT White Ops
Re: How to reset ECU? (Grimm)
Re: How to reset ECU? (PapaPark)
The easiest thing to do is to remove the HAZARD fuse from the underhood fuse box for about 1 minute then reinstall the fuse and start your car, let it idle for about 5 minutes then take it for a quick drive and shut it off. You wont have to reset your radio stations or anything.
