how to repair valve cover threads ?
hey guys I took my head to a machine shop a while back and had a valve job done & got a broken stud removed out of the head. However I think they damaged the threads while removing it because I went to put my valve cover on and come to find out There’s no threads in the hole, the bolt won’t even catch, it just sinks straight down. A heal a coil that fits the bolt won’t go into the head because there’s that little sleeve on the top. Whats the best way to go about replacing threads/fixes ? I’ve never had to do this before thanks In advance |
Re: how to repair valve cover threads ?
Anybody? |
Fill it full of jb weld and then drill and tap? Cold weld?
not really sure, haven't really had that problem |
Originally Posted by hybridnorth
(Post 51682783)
not really sure, haven't really had that problem kinda stumped here because I wanted to get the motor back in but this is holding me up. Ugh |
A Time-Sert for repair is a possibility. There are specific repair kits made for various model year Hondas.
Originally Posted by tech8
(Post 51683077)
That's tough dude. So I've only heard of this once but it's risky since this is a major component to keeping the head and block together tightly.
friend of mine did this and worked for about 2years then sold it so not sure if it worked passed that. Again, risky. He welded the hole shut completely as solid as he could get it basically like a "fill" and then drilled, tapped and re-threaded it. Again, risky since you never really know how completely filled the hole can be but if you have NO other options, fuck it go for it. I've seen worse try and get done but it's your motor not mine. I'd replace the damn thing with one that threads are good, that's only way you know for sure you'll be good. |
Definitely read that wrong. Just put some JB-weld and tap it then thread it. Should be fine.
