how to remove rear seats???
Re: how to remove rear seats??? (markpaco)
Cute. Anyways, on my 93 coupe(i'm guessing its the same as a hatch) there was a bolt in back of the cushion, right in the center. After that it should slide right out.
Re: how to remove rear seats??? (REVOEVOM)
Ok, all jokes aside. It's much easier to pull the backrest part out first. There is a bar that goes through the backs of both the left and right. There is a mount in the center between the two. Pull them to the side, away from the center, and they should unhook from the mount. Its one little nub that goes into the side of each seat. After you take both of those out, there is a bolt near the center but closer to the driver's side. Take that out, I believe its either 10mm or 12mm. You can then lift the back of the bottom up and slide it out.
New User
Re: no really.... (markpaco)
I'm not that mean...
It's pretty self explanatory. But seriously, buy a HELM manual.
PhatboyNYC
08-24-2003 03:03 PM
