HOW TO: Relocate fuse box into passenger cabin ( EG guys )
Would someone be so kind as to please let the masses know how to relocated the fuse box in the cabin, and where to run the engine harness connectors so they are hidden?
<FONT SIZE="10">Please!</FONT>
Re: HOW TO: Relocate fuse box into passenger cabin (SkRiBLaH)
Why? Ehh but since you want to know you should PM JDMlyfestyle I remember he was talking about doing that to someones car.
Re: HOW TO: Relocate fuse box into passenger cabin (99hatch)
jdmlyfestyle cleaned up the engine bay, not re-locate the fuse box.
if i am wrong correct me; bump
H-T Order of Merit
https://honda-tech.com/zerothread?id=1043518
Thats a good thread in the Fabrication/Welding forum. There are some helpful links in there and many pictures of what people have done.
1 Post
Re: (nojoke)
ug, pretty easy. Just unhook the entire fuse block, run the main line and then then engine harness wires threw, might have to extended them. Just go start it, and you will figure it out.
Re: (SkRiBLaH)
see if you wanna do it you should really figure that out yourself. you came up with the idea to do it. thats **** saying... "where ican i go to get a tattoo, and what should i get?"!!!!!!
Re: (xCIVICx)
obvious solution: run it to the glovebox...there on the same side and its easily accessible...remove your glove box...drill a rectangular hole thru the back of it(rectangular so whe u open and close it the wires have space to move) bolt or stick the fuse box in there voila...
fullraceacura
09-07-2005 05:24 AM
