How to put X brakes on your 96-00 EK civic (revised) upgrade chart
#127
Re: How to put X brakes on your 96-00 EK civic (HatchEh2)
does anyone have the front brake chart image saved? i could really use it for reference right now. please host it up if you have it
thanks!
-Luke
thanks!
-Luke
#128
Re: How to put X brakes on your 96-00 EK civic (lkailburn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lkailburn »</TD></TR><TR><TD CLASS="quote">does anyone have the front brake chart image saved? i could really use it for reference right now. please host it up if you have it
thanks!
-Luke</TD></TR></TABLE>
seriously... i knew i shoulda saved it
thanks!
#129
#132
Re: (GarageAlchemist)
Please redirect all questions to this thread, which contains an updated chart set.
https://honda-tech.com/zerothread?id=1811368
End thread.
End thread.
#135
the image for the front brakes is not working..
For some reason I am not comprehending all that info. I have an 88 crx that Im trying to install gsr brakes on.. What would I have to do? Is it possible to bolt on the gsr caliper to the crx spindle?
#136
Re: (akandok)
update on prop valves
Bottom line says si and dx, hx and civic, 3 door 1996 - 2000
have the same valve
I have called honda USA and confirmed this number.
2000 si 2 door
This image has been resized. Click this bar to view the full image. The original image is sized 800x400 and weights 52KB.
2000 non abs
46210-S04-902 VALVE ASSY., PROPORTIONING
crossing number:
46210S04902 $117.78 $0.00 $84.80
Brakes - Hydraulic system - Pressure metering valve
Pressure metering valve, civic, 2 door, dx model 1996 - 2000
Add to Cart Contact Us
Pressure metering valve, civic, 2 door, hx model, manual trans 1996 - 2000
Pressure metering valve, civic, 2 door, si model 1999 - 2000
Pressure metering valve, civic, 3 door 1996 - 2000
have the same valve
2000 si 2 door
2000 non abs
crossing number:
#138
is there any difference between ITR knuckler and SI knuckler? got som problem with my boots on the axel after i swaped from SI brakes to ITR brakes.. (96 civic EK)
#141
Re: How to put X brakes on your 96-00 EK civic (revised) upgrade chart
#142
1 Post
Im doing the rsx rears.
What brake hose do i use? I have integra rears right now.
So integra brake hose? Or rsx brake hose?
Ps i know this is an old thread
#144
about proportioning valves:
civic 99-00 SI prop valve: 46210-S04-902 (rear disk)
civic 96-00 2dr DX, HX prop valve: 46210-S04-902 (rear drum)
civic 96-00 3dr CX, DX prop valve: 46210-S04-902 (rear drum)
it was mentioned, that upgrading from drums to disks it is better NOT to use prop valve which came from car with drums. but the part number is the same. so, can i use the prop valve from civic DX, HX, CX?
#145
Many Thanks for this thread.
I believe, but don't quote, the prop valve is the same. The ones that are different are in older civics? Someone want to verify this?
#146
46210-S04-952 VALVE ASSY., PROPORTIONING 1998 INTEGRA RS
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC CX Hatch
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Hatch
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Coupe
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC HX Coupe
46210-S04-902 VALVE ASSY., PROPORTIONING 2000 CIVIC SI Coupe
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC DX Sedan
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC DX-V Sedan
46210-S04-912 VALVE ASSY., PROPORTIONING 2000 CIVIC LX Sedan
46210-S04-922 VALVE ASSY., PROPORTIONING 2000 CIVIC GX Sedan
46210-S04-962 VALVE ASSY., PROPORTIONING 2000 CIVIC EX Coupe
#150
I need some help. I got brakes for my 96 hatch dx but they do not fit right. The brakes say they fit a ex. Are the 96 dx the same as a ex. Please help
