HOW TO: My auto to manual swap PICS! 56k no no.
#176
Re: HOW TO: My auto to manual swap PICS! 56k no no.
Im having a simliar problem with my set up, I swapped the h22 into my auto civic also changed to a 5spd. When i give the starter direct power it will run just fine. However when i have the two large wires (blk/wht&blk/red) connected it wont allow the car to run it just keeps cranking..????? I have traced electrical diagrams for hours and am still haiving this problem. One other thing is that i have switched from a auto ecu to a standard ecu. Could you or anybody shed any light to these problems????
#178
i love this thread im gettin a auto ek friday for my ole lady and she wants a 5 speed so im motivated now ima do it thks
#180
Seagull Management
Yes.
Swap all of them, clutch and brake pedals are way to close otherwise. You can use the automatic gas pedal, but you need to use the automatic throttlecable too and it feels weird due to a spring mechanism for the automatic transmission kickdown/passing gear.
#181
I know this is an old thread but didn't want to make another one just for this question...When extending wire from clutch safety switch (yellow plug on top of clutch pedal) to the auto harness... What type of wire am I supposed to be using? Help would be much appreciated Thank You
#183
http://i181.photobucket.com/albums/x...7/DSCF0908.jpg
In this picture looks like he used a thicker gauge wire..do i need a thicker one like the one shown and if so what size it??
sorry for the noob question but this is my 1st build and I'm willing to hear everything out
#184
The Grumpiest
Use. The. Same. Gauge. Wire.
There is nothing else to hear out. Use a larger gauge wire if you want to possibly start a fire.
#186
I just did my auto to manual on 94 civic ex..everything is done but the time
I start the car it keeps revin up and down like 2krpm to 1rpm..i used the old ecu on it which is the p28 for auto all connectors are connected from ecu..please help
#187
Just read my old questions
So the clutch safety switch's wires from the pigtails are 20 gauge and the two thick black wires on the auto shifter harness are a lot thicker maybe 10 or 8 is it ok to run the 20gauge to here without a problem?
#189
If you're connecting a 20g wire to a 10g wire, use 12-14g wire.
#190
^ Please don't do this. Use a relay. The start-up current draw for the starter motor can reach nearly 200A. There is no sane way to use 20AWG wire for this. All the write-ups that connect the 10AWG wire directly to the clutch pedal are simply wrong. Even Honda uses a relay on an MT car for this purpose.
#191
So the two pins green and yellow they go back to the tranny? Or just looped? This will still work on a bseries swap into 94 civic hatch
#196
Thanx alot, planning to do a auto to manual swap in my da7 integra with a zc motor ama use a d15 hydro tranny this thread enlightened my knowledge abt doin the swap..thanx man
#197
i did the swap ur instrutions so help ful but now my check eng light is on did self dio on it sayin lock syl am i going 2 have 2 get a man esu r can i convert the old auto 1 so my check eng light will go off
#199
#200
Re: HOW TO: My auto to manual swap PICS! 56k no no. (ejoner)
just to add a tip...if u guys dont wanna run ugly lookn wires all the way to the tranny for the reverse lights u can find those same wires on the 14 pin engine harness plug on the driverside..if yur usdm that is...reason i did this is because i did a wire-tuck harness and didnt wana place any more wires in the bay..its #12 (yellow) and # 13 (green/black) on the plug..
uenolove
02-27-2008 04:32 PM
Intrinsic
05-07-2005 06:46 PM
KevronsEG
30
10-17-2002 01:26 PM
