How much NA-power is possible on a Z6??
How much Tourque an how many HP, would be expectable with theese bolts on:
Full Performance Exhaust (Supersprint, ??)
Cold air ( AEM, KN, ??)
Cam (ZEX, Crower, Skunk,????)
Cam gear ( Skunk,??)
Intake Manifold (Y8, Edelbrock, ??)
I Am going to build up my Z6 with the above (got some of it alredy ) and perhaps other pistons (if it is worth it!!)
But how much power will, I be able to pull out of the single cam screamer??
M. Nielsen Denmark
M. Nielsen Denmark
Re: How much NA-power is possible on a Z6?? (ApexI EX)
with those mods you should have between 125-140 atw im guessing. good choice in staying with the single cam! good luck with it
depending on hte car its going into it'll be worth it... if its an ek... it might be too heavy... on an EG with some weight reduction it'll be fine. a member here on h-t ran a 14.1 on street tires EG with d16z6 and bolt ons. (and chipped ecu) he had weight reduction as well....
im doing a mini setup on my EG...
Re: How much NA-power is possible on a Z6?? (cjames235)
It's an EG hatch.. And In Denmark we meassure at the flyweel.. and now I am at 140HP (not at the weels!!!) only with the Intake and SP Exhaust.... Don't know how much that is on the weels.???
I think the next thing will be a Cam... (ZEX or Crower.)
M. Nielsen, Denmark
M. Nielsen, Denmark
with those mods you should have between 125-140 atw im guessing. good choice in staying with the single cam! good luck with it- '97 CIVIC EX
-AEM CAI
-Thermal Cat-Back
-b&m shifter
-ground controls
-st sway bars
best time- 16.0 @ 84
-AEM CAI
-Thermal Cat-Back
-b&m shifter
-ground controls
-st sway bars
New User
Re: How much NA-power is possible on a Z6?? (SOHC_DK.)
I am currently ~128 HP and ~110 Ft/lbs at the wheels with basic mods
- I/H/E, lightened flywheel, Zex cam, Y8 IM, and a chipped ECU.
With Race a race header, P29 Pistons(12:1 compression), 94 octane gas, heavilly retartded timing and some HonData tuning I should be up to the 150-160 Wheel HP range.
The Z6 is a pretty good platform for LO_BUCK power ... you will never make huge NA power .... but with some good weight management(reduction) you will do pretty good on the track.
My Z6 build-up will cost arround $600 USD for machining and parts and if I do the assembly dis-asembly that is all it will cost .. so for under a g-note including the motor, I should have B18C1 levels of power for way less $$$.
The Best thing about the Z6 is that it is cheap ... if you blow it up ..who cares ... buy another one for $200-300 .... slap it in and you are good to go ... Blow up a B18C and you will be looking for financing : )
Cheers
Moose
Re: How much NA-power is possible on a Z6?? (Moose)
Solbros Owns Me
Re: How much NA-power is possible on a Z6?? (SOHC_MShue)
not much . I would consider a turbo. Thats what i'm planning on. I don't see much power in the future of my d16y8 without a turbo.
M. Nielsen Denmark
M. Nielsen Denmark
Re: How much NA-power is possible on a Z6?? (nasi)
https://honda-tech.com/zerothread?id=335078
peep this might help you
This is my buddies 92 DX. It has a D16Z6 swap. The engine has:
JG cam
JG cam gear
DC 4-2-1 header
no cat
Chipped ECU
custom exhaust
Its an auto cross car. This car ran a 15.4 in the 1/4 mile.
Solbros Owns Me
Re: How much NA-power is possible on a Z6?? (ZC_CRX)
I ran a 15.5 with 2.3 60 footer, with intake, exhaust, and a 3 angle valve job.
I'll post some times soon with:
ZEX 59300 cam
fresh Z6 block with p29 pistons
crower springs
.020 mill
ZEX 59300 cam
crower springs
.020 mill
Former Moderator
Re: How much NA-power is possible on a Z6?? (redcxhatch)
I'll show you guys what an all-Honda parts bin D16A6 motor can do...the build up is about to get started!
I'm dead serious - SOHC power biatches!
Former Moderator
Re: How much NA-power is possible on a Z6?? (Emerica)
what are the plans!? I like the D16A6 out of all the SOHC's for some reason
I tell my plans there.
Solbros Owns Me
Re: How much NA-power is possible on a Z6?? (B18C5-EH2)
Sorry to hi-jack, but check my new topic Emerica, thanks.
Re: How much NA-power is possible on a Z6?? (97GSR Hatch)
Sorry bro but 16 flat in the quarter is lame! Dont you get pissed when stock v8 trucks beat you?? Please consider a turbo before taking apart that D series...
Not fast at all...probably run a 16.7 bone stock...
hitting a 16 flat with just a few bolt ons is awesome....
I hit a 16 flat with just an intake and headers..stock exhaust, stock cat, stock piping..., full interior, 115,000 miles, 2.3 60ft.. on my 93 ex coupe....
I know i took the easy route as well as you from your name..buy swapping motors....(97GSR Hatch)
but using whats in your car originally and making it fast is pretty damn cool...
I used to think that the only way to be fast is to swap your motor out...but from seeing a 10 sec all motor dseries run, anything is possible.
also, my bro loves his d series also, a d16a6 non vtec in his 91 civic hatch...he slapped a revhard turbo on it and he ran a 13.9 at 8lbs....now you want to talk about a car thats not too fast stock??
Re: How much NA-power is possible on a Z6?? (JdmVetteEater)
Look at my mods, and I just ran a 12.98 @ 108, that says that sohc rocks...
