How much does it cost to put a hssa into an eg
Location: With my POS D15B2, Whereever whenever, United States
How much does it cost to put a h22a into an eg
As topic says.
The motor is 2k give or take
how much wiring is need?
Modified by MugenHonda at 6:59 AM 4/12/2003
Re: How much does it cost to put a h22a into an eg (MugenHonda)
The search function works wonders, my friend. In particular, there is the Hybrid forum with TONS of info.
In brief, since I'm assuming you have a hatch, you will need to adapt your factory civic harness to the H22A and most likely need to wire VTEC (if you do not have an EX/Si), knock sensor (unless you're running a chipped ECU or P28), extend alternator wires to reach the H22A alternator, and convert to the H22A injector harness plugs, as well as wire up a resistor box.
For more info, search function is your friend.
