How much amperage does a Stock 2000 Honda Civic EX alternator push out?
How much amperage does a Stock 2000 Honda Civic EX alternator push out? i need to know because i just fixed my system, and i dont know if i am in danger of ******* up something later on......I know that the the alternator is supposed to push out mid 12's volt with the car off, and low 14's volt when the car is on....now i need to know how much amperage the alternator pushes out....
Re: How much amperage does a Stock 2000 Honda Civic EX alternator push out? (stillencivic)
Re: How much amperage does a Stock 2000 Honda Civic EX alternator push out? (97hb)
Re: How much amperage does a Stock 2000 Honda Civic EX alternator push out? (fangtl)
actually the alternator does. i checked with several sound companies...so it pushes around 70 amps for a stock alternator....?
The alternator is driven by the engine, therefore it must be running. 14 Volts/70 Amps. About 50 of those amps are used to keep your car running.
~70 amps is at crusing speed, the Civic probably has only about 30 amps at idle. If you want to make sure just bring it into a shop and have them do an alternator test for you.
I got this done at pepboys for free
Ok, I have a quick question.. regarding something close to this same topic.
2000 Honda Civic EX Coupe
I'm about to upgrade my "Big 3" and was curious as to what amp fuse to use from the alternator to the battery. I've bought all 1/0 gauge wire, new terminals, inline fuse holder, 200amp fuse and conector rings. I read that the stock alternator is pushing around 70amps, I'm wondering how many amps it would be pushing with the 0 gauge wire installed. Should I downgrade to a 100amp fuse or keep the current 200amp ? I don't want it to blow up my battery, once I've got everything installed. Going to be grounding the battery with 1/0 gauge to the strut and to the engine block, then running a power wire over to the alternator 1/0 gauge as well with an inline fuse (200amps).
Jammersplace
02-14-2005 06:05 PM
CooBlueDAB
04-06-2004 09:33 AM
