how many wires to ignition is TOOO much??
i have a gauge, turbo timer and boost controller all hooked up to my ignition wire on the harness. i was wondering if it would be bad to install one more wire to that wire for my fuel pump. please let me know. thanks alot
Re: how many wires to ignition is TOOO much?? (tyflip2)
What boost controller needs to be wired up? You mean a SAFC?
The gauge doesnt take up much power, i would run that straight to the batt. I think Turbo Timer, and fuel pump would be ok.
H-T White Ops
I wouldn't risk it. Your fuel pump draws a hell of a lot more amperage than a few gauges do. I suggest you pull ONE wire off your ignition to power a relay. Much much safer that way. That's what I plan on doing once I get all my stuff ready to go in. I'll be running a turbo timer, 4 gauges and a fuel pump. I'm probably going to run 2 relays. Not sure yet. But like I said, if I was you I'd run a relay to power all that stuff.
