how to make sohc vtec fast no turbo
Re: how to make sohc vtec fast no turbo (jonas)
drop it into a lawnmower that'll be one hella fast lawnmower if you don't give a rat's *** about the motor built it up and put NAWWWWSSS on it!
[Modified by cyrk007, 2:10 AM 7/9/2002]
Re: how to make sohc vtec fast no turbo (01-0720)
You should start with a light car....a lot of money.
You'll probably spend more on building up the z6 to get it equal to a decent swap...but if that's what you want to do, then to you!
Honda-Tech User
man dont listen to all these people about not doing a SOHC if thats what you want to do then do it. it all depends on how fast you want to go. if you want to run 14's its not hard or exspensive on a SOHC VTEC (in a HB anyway). Like MISTA BONES said use a Nitrous kit and you will run 14's just on Nitrous. If you dont want to use a fored induction motor, then i would say go with the basic first I/H/E then do a CAM (bulfrog has a good head packacage). Im just saying ts not hard or exspensive to run 14's but the lower you go the more it is. 13's arent really exspensive.
Steve
Steve
Honda-Tech User
Re: how to make sohc vtec fast no turbo (Mista Bone)
i was thinking that his civic is complety stock and its probably a coupe. it would be hard to get it in the 13's with just NOS. and he probably only wants to run a 60 shot or less, i wouldnt recomend anythign bigger then that on a stock fuel pump, (just better to be safe)
drive it off a cliff
Re: how to make sohc vtec fast no turbo (dom93hatch)
NOS..or NaaaaaWWwwwWwWZzzzzZZz ...i dont know the difference between the two but the stunnaz tell me the second one gives you more vtec
MiG-21 superfan
Re: how to make sohc vtec fast no turbo (spankaveli)
thanks spanky!
fast is a relative term, mid-thirteens all motor good enough?
http://www.fuziononline.com/rides/97civichb/index.shtmland http://members9.clubphoto.com/builthatch543239/698762/guest.phtml
[Modified by builthatch, 1:17 PM 7/9/2002]
[Modified by builthatch, 1:21 PM 7/9/2002]
[Modified by builthatch, 1:22 PM 7/9/2002]
Re: how to make sohc vtec fast no turbo (MiGs)
Spank?! WHOA, whereve u been man. How is the Civic?
driving a 95 240SX SE now, hoping for SR20DET soon, after suspension and brakes upgrade
back on topic, sohc vtec motor in a CRX or VX/CX hatch will make good times stock, but with boltons, maybe a zex cam and some nitrous you should be hitting 13s easily
