How to install camber kit
Could someone give me a link to a site on how to install a front camber kit on a 00 Civic Si this is the kit with control arm an all.
thanks
Later
Matt
thanks
Later
Matt
you dont really need a how to...its really simple
but...
Tools Needed
-14mm Wrench
-17mm Wrench
Parts Needed
**Removal of the shock body is also NOT needed**
-First remove your wheel and jack the car up
-Then Remove the 2 14mm Bolts holding the A Arm inplace (inside engine bay...NOT the nuts! Passenger side you have to move the battery)
-Then place a deep socket 17mm Wrench and remove the castle bolt holding it in place
-Remove A Arm
-Install new arms...put codder pin in similar to how it was stock (or not...doesnt really matter)
but...
Tools Needed
-14mm Wrench
-17mm Wrench
Parts Needed
-Remove A Arm
Re: (insomniac791)
hahaha oh man, very vague description... assuming your kit is similar to the skunk2 kit...
Unbolt the anchor bolts from the subframe ( i believe its called, inside the engine bay, 17mm )
Remove the cotter pin, ball joint nut and use a ball joint splitter to carefully pop the ball joint out. (or use a hammer and hit the arm until it shakes loose)
Move the arm out of the way and lower the upper control arm down still connected to the anchor.
Without removing the shock unbolt the anchor from the upper control arm.
Pull out the old arm and then bolt the new upper control arm (camber kit) to the anchor bolts. (NOTE: you will note be able to remove the anchor from the upper control arm without enough room to slide the bolts out of the anchor bushings, thus sliding it down where there's room to work with it is necessary)
Slide the new control arm, bolted to the anchors back up.
Slide the bolts on top of the anchor back into the engine bay and hand tighten those nuts to hold it up there.
Bolt the arm back up to the control arm and dont forget a new cotter pin
Torque everything back up/down, greese the ball joints and you should be good.
If i have forgotten anything back me up or ask, i rushed through this
good luck
-Bryan-
good luck
-Bryan-
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">
-First remove your wheel and jack the car up </TD></TR></TABLE>
I like this step...it's kinda tricky...
Just messin around man...I know what your sayin...
alright thaks for all the replies.
EGStreetHtch thanks for the how-to it will be really helpful.
I am going to attempt to do it on Saturday so if I have any questions I will post then.
later
Matt
later
Matt
Re: (axhandler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axhandler »</TD></TR><TR><TD CLASS="quote">
Just messin around man...I know what your sayin... </TD></TR></TABLE>
hey man...ya never know what people are thinking when they do this stuff. Maybe they've never even changed their own oil...
I diid the washer trick thing on the back today and added 3 washers. The tires still camber in? Is it safe to add more than 3 washers?
later
Matt
later
Matt
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">you dont really need a how to...its really simple
but...
Tools Needed
-14mm Wrench
-17mm Wrench
Parts Needed
-Remove A Arm
-Install new arms...put codder pin in similar to how it was stock (or not...doesnt really matter)</TD></TR></TABLE>
Super easy install!
Here is a link with some pics that might help!
https://honda-tech.com/zerothread?id=602750
but...
Tools Needed
-14mm Wrench
-17mm Wrench
Parts Needed
-Remove A Arm
Super easy install!
On the one he has got the I can't get the bolts to line back up that go through from inside the engine compartment. the new A-Arm that goes up into it is alot larger than stock. Can i dent the inside of the fender to make it fit?
Am I makeing any sense?
Later
Matt
Later
Matt
Steve90HB
09-04-2003 12:47 PM
