How to install autometer Gauges???
I bought auotmeter air/fuel and water temp. gauges to put on the a-pillar. The directions are kind of confusing. Any help will be great.
Thanks
Thanks
Re: How to install autometer Gauges??? (clutch33)
for the a/f guage you can wire it into the ecu if you are very carefull or you have the opition of wiring it to your O2 sensor . go to autometer.com then go to tech tips. not exactally sure bout the watertemp gauge, possible to wire into the back of the instrument cluster off of the stock temp gauge. Why do you need autometer water guage when you have stock one.?????
Re: How to install autometer Gauges??? (ricerocket2nv)
I broke the needle off the stock gauges installed indiglow's. I figure the wires and sensors are still good, so I am going to try to wore it to the back of the cluster. Which wire though????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricerocket2nv »</TD></TR><TR><TD CLASS="quote">p.s if you go into your O2 sensor you will have to jump into the green wire.</TD></TR></TABLE>
I thought it was the white wire?
turbotime
11
09-30-2005 05:03 PM
