How hard/easy is it to change an axle??
Re: How hard/easy is it to change an axle?? (Type R106)
not that hard. I've watched someone do it. It's just a little messy (don't forget to drain the tranny first). and you should probably get two new axle seals while you're at it, and there's a cotter-pin or two in there (the hub assembly I think) that may get mangled on the way out and need to be replaced.
Get a Helms. Follow the steps.
oh. and it's much less fun if you don't hav a lift and air tools. At least air tools, because it's really hard to get the hub nut off without that power.
its not hard, i did it and the hard part was getting the old one out. put the new one in is the easy part.
Former Moderator
Re: How hard/easy is it to change an axle?? (rookie2nr)
Tools you'll need if doing a Civic or Integra:
19mm for the wheel
32mm big-*** socket and BIG rachet for it - to break off and tighten back up the axle nut
17mm wrench
17mm wrench again or rachet
Dykes
Hammer
Prybar
TRY to get the entire front of the vehicle off the ground so you can turn the wheels to make things easier.
1. Take the wheel off with the 19mm
2. Take the 32mm nut off the end of the axle
3. Take the dykes and pull the cotter pin out of the bottom 17mm castle nut on the lower balljoint
4. Take the 17mm and remove the castlenut from the lower balljoint
5. Take your big-*** hammer and whack right ON the lower control arm where the balljoint sits - this method for buting the balljoint out will not tear the balljoint boot like the "balljoint wedge" will
6. Take both 17mm and remove the thru-bolt that runs through the lower fork of the front stut - this will allow the axle to slide out when ready by pulling the strut fork to the side of the lower control arm
7. Pull the brake rotor out of the way - axle is ready to come out
8. Take the prybar and pry the axle by prying between the inner joint and the tranny housing
**CAUTION**
If it's a manual tranny you NEED to drain it if you're doing the PASSENGER side on a car with equal-length driveshafts - if it's a B-series this applies. Unequal length shafts will require yopu to ALWAYS drain the tranny.
Reassamble it how you disassembled it. Only then you need to stake the axle nut down by putting a dent in it and do'nt forget to replace the cotter pin in the lower balljoint castlenut!
19mm for the wheel
17mm wrench
Dykes
Hammer
Prybar
**CAUTION**
wdskuk
16
07-25-2004 12:21 AM
