how to get more power into a d15
hey guys i was juss wondering if u could give me some suggestions on how to pull power out of my stock d15 right now i have i/h/e is there anything i could do to get some power i was gonna get a port and polish done has anyone done this and how much power will i gain sorry if i sound like a newbie
Re: (company7)
http://www.homemadeturbo.com
BTW what kind of d15 do you have? b7 right? at 5psi you would beat 70% of the ppl you race, dont waste money on bolt ons you can customize your own turbo kit for under 600 bucs...do some research imo
Re: how to get more power into a d15 (jdmbuilt)
assuming it is a D15B7, throw on a z6 head with a y8 intake manifold, add a b-series throttle body. Then do the regular I/H/E, then add a Zex 59300 or look to skunk2.
If you do not want to swap the head then look into a crane cam made for the d16a6, it will work in the d15 (have to adjust though). Then add the y8 IM, and b-series throttle body with the I/H/E.
Re: (krazySOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazySOHC »</TD></TR><TR><TD CLASS="quote">http://www.homemadeturbo.com
BTW what kind of d15 do you have? b7 right? at 5psi you would beat 70% of the ppl you race, dont waste money on bolt ons you can customize your own turbo kit for under 600 bucs...do some research imo</TD></TR></TABLE>
This is the way to go if you want to make somewhat decent power without spending alot of money.
Re: (EVIL Hx Coupe)
if i add the z6 head would i need to change anything else or will it just bolt on and does anyone have a DIY on the install? tia
Re: (oneslowej)
the z6 head will require a z6 head gasket, a vx timing belt, a p28 ecu to run it properly and you will need to add 3 wires I think to run vtec.
I am not sure about head studs, you need new ones I believe, but am unsure of which to use.
Re: (chillax)
B16 $800. How much are intake, header, exhaust? You prolly already spent more than enought to get a $600 D16 and maybe even a $800 B16. Oh yea, scre all motor, go turbo.
Re: (Neptune)
where the hell are you finding a b16a for $800???? Maybe engine alone, what about tranny, axles, ecu etc?
If you are talking about the first gen B16a then he would have some issues installing that motor.
To get a b16a 2nd gen swap it will cost much much more than $800, especially factoring in all the parts and labor.
