How the F*** to remove shift linkage...
Well I am getting ready to do my swap and I am slowly pulling out my blown single cam as I have time. Today i removed all the exhaust and attempted to remove all the shift linkage and shifter.
well I got teh shifter out and one of the two bars that attach to the trans. Now I can't seem to figure out how the hell to get the shift linkage disconnected from teh trans?
Please refrain from posting some dumb *** comment as it is getting dark and I am trying to get this done...
here are a few pictures for you
Lets see who knows there ****... i thought I did...
Re: How the F*** to remove shift linkage... (Jon V)
I BELIVE you have to pull the rubber bushing back a lil bit or something and there is a lil metal pin you have to push it out might be on the outside..but I know there is a lil metal pin that holds it in try pulling the bushing back a lil bit
Re: How the F*** to remove shift linkage... (DoctorVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoctorVtec »</TD></TR><TR><TD CLASS="quote">I BELIVE you have to pull the rubber bushing back a lil bit or something and there is a lil metal pin you have to push it out might be on the outside..but I know there is a lil metal pin that holds it in try pulling the bushing back a lil bit</TD></TR></TABLE>
Thanks
Thanks
I am a (Trial User) Army
Jon,
Pull your old motor. Don't worry about the ******* linkage.
See the linkage that I didn't bother wit;h.
Re: How the F*** to remove shift linkage... (litterbox)
LoL I'm just going to do that **** tomarrow.
I don't want to pull the motor because I am not sure exactly when the new one will be going in, and I don't want my suspsnsion decompressed for 2-3 months...
You **** face...
You **** face...
Pull the rubber boot back, and there is a C clip, pop that off, and there is a roller pin in there. It will be a hell of a lot easier, if you have a roller pin punch tool. use that, and a good hammer, and punch it out. But, chances are you dont have a punch. So, another good "tool" is the long bolt that holds your AC compressor on. It happens to have atapered end, that fits perfectly on the pin. Use that, and the hammer, and pound it out.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DoctorVtec »</TD></TR><TR><TD CLASS="quote">Did my info help at all man?</TD></TR></TABLE>
we'll see tomarrow...
I'm done for the night... I think you are right though because I don't see any other way. I was about to bust out the hack saw...
i kinda figured thats what it was but that boot doesn't move much. I'm probly just going to cut it off...
Thanks for the quick responce...
Andy thanks for nothing... Just jokin man
Re: (my_slow_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my_slow_civic »</TD></TR><TR><TD CLASS="quote">Pull the rubber boot back, and there is a C clip, pop that off, and there is a roller pin in there. It will be a hell of a lot easier, if you have a roller pin punch tool. use that, and a good hammer, and punch it out. But, chances are you dont have a punch. So, another good "tool" is the long bolt that holds your AC compressor on. It happens to have atapered end, that fits perfectly on the pin. Use that, and the hammer, and pound it out.</TD></TR></TABLE>
of course I have a punch, I just don't have a brain to figure out where I need to put it...
I'm getting ready for my K swap (some day, ahh). It's just been a bad day so I needed to work on the car to let out some frustration. then I get everything done excpet removing that one rod...
Re: (Jon V)
I was right
I was right
Re: (my_slow_civic)
Props to you, i use the long AC bolt everytime i have to remove the linkage, its like it was made for it, just use that and you wont believe how easy it is.
Re: (b18cKoupe)
I used a flat punch, and the bitch pin came right out. I dunno why everybody freaks out on it so much. I was all worried about it because of what I read on H-T, but it was a breeze
Re: (b18cKoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cKoupe »</TD></TR><TR><TD CLASS="quote">
i use the long AC bolt everytime i have to remove the linkage, its like it was made for it, just use that and you wont believe how easy it is.</TD></TR></TABLE>
couldn't have said it better myself
Re: (donut.)
I got so tired of this pin because my jack stands are so short which gave me no room to swing a hammer. To complicate this the pin was nearly rusted in place. I never did get the thing out!
So I just pulled the engine out while I had two buddies lifting up on the car to provide clearance for the shift linkage.
Once out, I took a grinder and ground off the heads on the rivet that keeps the knuckle together. I replaced it with a grade 8 bolt and self-locking nut with a drop of locktight.
Now, pulling the linkage requires no pounding nor cussing!
Re: (SpydiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpydiR »</TD></TR><TR><TD CLASS="quote">I used a flat punch, and the bitch pin came right out. I dunno why everybody freaks out on it so much. I was all worried about it because of what I read on H-T, but it was a breeze </TD></TR></TABLE>
Because people don't get the right tools to do it and then they wonder why it takes them forever.
Re: (boomtick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boomtick »</TD></TR><TR><TD CLASS="quote">what would be a good tool to put the rubber boot back on? The rubber boot on my linkage is pulled back and you can see the pin
sorry to hijack your thread dude </TD></TR></TABLE>
your hand...it's just a rubber boot
Re: (FERIOkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FERIOkid »</TD></TR><TR><TD CLASS="quote">
your hand...it's just a rubber boot</TD></TR></TABLE>
lol pwned
lol pwned
You pull the rubber boot back, then use a hammer and 8mm roll pin punch and pound the **** out of the roll pin, it's easier to hammer up towards the car also.
Replace the roll pin regardless of what ppl say, they are like 20 cents.
good luck
good luck
