how does this setup sound to u guys
Old 07-25-2002, 07:48 AM
drvfast's Avatar
Default how does this setup sound to u guys
its a 1994 eg
b18c1
99-00 si tranny
itr cams
itr pistions p73-00
itr valesprings and valves
skunk 2 intake manifold
itr throttle body 62mm
jdm 4-1
aem cold air
apexi ws exhaust
b&m fpr
apexi vafc
4.929 final drive
also an lsd
excedy clutch and 9lb flywheel
is this a good setup? should i use the si tranny over the gs-r tranny? what do u thing this setup could run in 1/4 or how much power to the wheels just an estimate?i planing to just do autocrossing but when i get this done i will run it in the 1/4 to see what i run. feel free to add anything that might be better. thanks
Old 07-25-2002, 09:19 AM
drvfast's Avatar
Default Re: how does this setup sound to u guys (drvfast)
anyone
Old 07-25-2002, 09:26 AM
714eg's Avatar
I would have to say that's a good setup but depending on the driver and where your running if it was in Cali @ like Palmdale in which elevation is a bitch that would pull 14.3-14.5 probably
Old 07-25-2002, 09:31 AM
Doctor CorteZ's Avatar
sounds like a nice little set-up
Old 07-25-2002, 09:33 AM
Ehron's Avatar
Sounds like you won the lottery...
drvfast's Avatar
Default Re: how does this setup sound to u guys (Doctor CorteZ)
i'm in florida good driver
Old 07-25-2002, 09:36 AM
4g4me's Avatar
You might as well just get yourself a JDM or USDM ITR changeover. Sounds like that is what you are trying to build. Prices are going down.
Old 07-25-2002, 09:37 AM
Future Texas Boy
vtecvoodoo's Avatar
sounds like you are gonna spend quite a few pennies to run 13`s
If you are going to autoX, why not go a little less extreme on the motor and take driving school or two? Or buy an extra set of wheels w/ supa sticky tires, cage n harnesses, etc etc
Just my opinion. I`m sure the setup you described would be fun though.
[Modified by vtecvoodoo, 6:46 PM 7/25/2002]
t-blizzard
05-11-2005 02:00 PM
bulori
02-29-2004 04:29 PM
bobbysteelz
06-10-2003 06:13 AM
Crxtasy
02-19-2002 07:57 AM
MXPX
01-30-2002 12:35 PM
Quick Reply: how does this setup sound to u guys
