How do you use the R-Spec VTEC contoller
I just recieved mine the other day, but it did not come with any directions. Does any one know how to use this set up if so any info would be greatly appreciated.
Re: How do you use the R-Spec VTEC contoller (JUN EK9)
It i sthe one at this address:
http://www.nextcollection.com/...e.cfm
Re: How do you use the R-Spec VTEC contoller (reward_1000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by reward_1000 »</TD></TR><TR><TD CLASS="quote">It i sthe one at this address:
http://www.nextcollection.com/...e.cfm</TD></TR></TABLE>
holy ****. $360 for that POS? you can get an apex'i vafc-II for less, and u can adjust ur fuel curves too (sorry for the lack of info in my post)
haha send it back and get a vafc. you got raped.
is your engine heavily modified? if not, by changing the vtec xover your probably actually going to lose power. the only way to set it and gain from it is on a dyno, and if your engine is close to stock you're wasting your time. i think you knew that already though.
it says on their website professional installation recommended - no harness available, and you don't have directions. good luck.
try searching for it here and on google.
Re: (jwn7)
I did not pay that for it, I paid a hundred bucks for it, I am not crazy. Please just post some ideas on hoe to use it instead of this worhtless info.
Re: (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">
try searching for it here and on google.</TD></TR></TABLE>
see what he said yep listen to him. i sure hope you have modification that will net that 100 dollars worth something, cause if you don't your gona losse power. but then again if you did have those mods then you would be running some sort of fuel managment, which inturn would allow you to adjust vtec
Re: (slammed_93_hatch)
Well I do have the harness and it seems to work, I just wnat to know how to adjust it, and for your info I am an ASE master tech.
