How do you install/align window?
Anyone know step by step install for a driver's side power window on a 1997 civic EX? My friend and I are having trouble aligning both sides of the window. Anybody know any tricks or anything for this? Thanks
Re: How do you install/align window? (LOwrestling2001)
You mean put it on track? When I installed a new regulator in my car, I had my friend put the window in the track as straight as it could be and inside the rubber. Then I lifted the regulator up to the window and bolted it up. Now, if you regulator isn't bolted straight in your door, the window will roll up off-track.
I bolted up the regulator to the door first. Then I aligned the window inside the track. I moved the regulator up. In your case, pressing up on the window switch until the part of the regular that bolts to the window is right under the window. Then I bolted the window to the regulator.
crxaddikt
17
01-13-2015 04:04 AM
import-tooner
03-03-2010 04:19 PM
EnKidu
10-10-2004 06:43 PM
