how do you fix a "crank angle", "no.1 cylinder", and "ign. output signal" codes
Old 09-23-2005, 10:52 AM
EG93si's Avatar
Default how do you fix a "crank angle", "no.1 cylinder", and "ign. output signal" codes
as it states, my cars running like poo. cuts out at 3k and a geo could take it
Old 09-23-2005, 11:05 AM
bman511's Avatar
Default Re: how do you fix a "crank angle", "no.1 cylinder", and "ign. output signal" codes (EG93si)
sounds like your distributor, i think mine was throwing a no.1 cylinder when my distributor was bad. wat kindof motor?
Old 09-23-2005, 11:26 AM
EG93si's Avatar
sir-II b16
Old 09-27-2005, 09:08 AM
EG93si's Avatar
Default Re: (EG93si)
bump
Old 09-27-2005, 09:15 AM
Luserkid's Avatar
How many threads are you going to make abou this?
Old 09-27-2005, 09:20 AM
Former Moderator
B18C5-EH2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG93si &raquo;</TD></TR><TR><TD CLASS="quote">how do you fix a "crank angle", "no.1 cylinder"</TD></TR></TABLE>
Replace the distributor base.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">and "ign. output signal" codes </TD></TR></TABLE>
Replace the coil and/or ignitor usually.Or visit http://www.distributorking.com and order the TD44U unit. It comes as a 100% complete unti with the base, ignitor, coil, rotor button, and cap all preassembled all for about $250.00 or so.
Honda sells the base, coil, and ignitor separately for over $500.00.
Old 09-27-2005, 09:35 AM
Bull_head360's Avatar
just a thought, before you spend big $$$, take the cap, rotor, and that plastic shield thing off your dizzy (in that order) and wipe the metal stuff off the sensors. It might be built up really bad. (the sensors are magnetic so build-up can happen) I got a code on 1 of the 3 sensors in there, cleaned that sensor and it was fine after that, goodluck
Old 09-27-2005, 10:26 AM
EG93si's Avatar
Default Re: (Bull_head360)
thanks, thread dead
Old 09-29-2005, 06:29 PM
EG93si's Avatar
wait, not dead, i just replace my entire distributer, cap and rotor and know im flashing all the same codes plus #8, wtf, do i need to reset the ecu or somehting, it runs fine but i dont want to trash the new 300$ distributer
ej1 assasin
11-14-2006 07:42 AM
520_Motorsports
02-23-2006 09:33 PM
rfactor
12-05-2005 08:16 AM
Xxcivic99xX
10-24-2004 01:07 PM
SI_niki
06-15-2004 07:54 AM
Quick Reply: how do you fix a "crank angle", "no.1 cylinder", and "ign. output signal" codes
