How do you change a Distributor on a 93 del sol
The distributor is making a lot of noise on my 93 del sol. Im going to replace it but i have never replaced one before.. Are there any online directions to do so? Are they easy to replace? What kind of tools are needed? Do the gears need to be aligned a certain way?
Thanks for any help
Thanks for any help
Re: How do you change a Distributor on a 93 del sol (mkiv_tt)
I changed mine this weekend. 3 bolts and 2 plugs and it comes right out. Have a rag ready to stop oil from coming out of the hole. Make sure you note the location of the rotor button so you can adjust the new distributor to match the slot on the end of the cam.
I picked up a remanufactured distributor from Napa for $194. Good luck!
Solbros Owns Me
Re: How do you change a Distributor on a 93 del sol (92hatchdude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hatchdude »</TD></TR><TR><TD CLASS="quote">I changed mine this weekend. 3 bolts and 2 plugs and it comes right out. Have a rag ready to stop oil from coming out of the hole. Make sure you note the location of the rotor button so you can adjust the new distributor to match the slot on the end of the cam.
I picked up a remanufactured distributor from Napa for $194. Good luck! </TD></TR></TABLE>
it should only go on one way though.
Get a timing light to get your ignition set back to stock once your're done though.
Re: How do you change a Distributor on a 93 del sol (Emerika)
so the distributor will only go in one way then i need to ajust ignition timing when im done?
Thanks
Thanks
thordain
11-20-2010 09:08 PM
Motown Del Sol
11
09-06-2009 05:48 AM
itsmejto
10-25-2008 04:04 PM
sciclunam
04-01-2006 08:01 AM
SmokeU
11-05-2003 11:35 AM
93, adjust, change, chnge, civic, del, distribuitor, distributor, distributors, honda, needed, replace, replacement, sol, tools
