How do u wire the gas light on JDM EG cluster?
i searched and know my car doesnt come with 1 and there isnt an how-to. anybody know whats involved?
i guess u would need the teg float with the sensor on it, but where do u run the wire to on the cluster?
Re: How do u wire the gas light on JDM EG cluster? (CRXified)
would like to know this also since its kinda gay my car has no gas light..........only car I have ever owned that dosent have one lol
Re: How do u wire the gas light on JDM EG cluster? (ECKO1980)
do u have the JDM cluster with the light in it? if u dont i dont think u can hook it up unless u make a spot in ur cluster for a light or something
bump
bump
i would like to know this and the door indicator on my eg9 cluster
Our Civics never came with low fuel lights from the factory therefore it wont be easy to hook up the light. You could get a low level sensor from an Integra.
I came up with a circuit that reads the resistance from the fuel level sensor and runs it through a comparator and turns on the light when the level gets to a preset level.
Here is my solution.....
Re: How do u wire the gas light on JDM EG cluster? (jdmeg9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmeg9 »</TD></TR><TR><TD CLASS="quote">i would like to know this and the door indicator on my eg9 cluster</TD></TR></TABLE>
Hook up the wire from the door light on the cluster to the dome light wire in the drivers side a-pillar, I believe it's the green/white wire. You will have to double check if it's the green/white or the white/red.
Re: How do u wire the gas light on JDM EG cluster? (mrchaos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrchaos »</TD></TR><TR><TD CLASS="quote">Our Civics never came with low fuel lights from the factory therefore it wont be easy to hook up the light. You could get a low level sensor from an Integra.</TD></TR></TABLE>
by low lever sensor u mean the 1 thats in the tank right? if they have that, then the integras must have some kind of circut like u made to turn the light on already in them, or is it in the cluster its self?
Was going to make a hybrid one using a teg & civic but I used an SiR Fuel Sending unit instead. I found one on ebay.
Swapped out the units. Ran a wire from the plug @ the fuel sending unit. Ran it to the dash and wired it up the correct pin
location(#7 on 10 pin plug on the back of the cluster). It works great.
I luckly saved the instructions. If anybody needs it just PM me.
Modified by Accord SiRT at 9:24 PM 1/17/2006
Easiest thing to do is put in a teg sending unit. wire it up, be done... for me, I just tell myself "I think I need gas" when the gauge reads low.
Re: How do u wire the gas light on JDM EG cluster? (Hybrid93Eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg »</TD></TR><TR><TD CLASS="quote">Easiest thing to do is put in a teg sending unit. wire it up, be done... for me, I just tell myself "I think I need gas" when the gauge reads low.</TD></TR></TABLE>
lol that works too, but i like lights and its jDeem y0
egvtec
13
05-15-2010 12:13 AM
