how do u check for codes?
Today i was checking my ecu for codes with the haynes book which it didnt help a lot. The manual said there is a connector which is located under the dash on the passanger side along the glove compartment, on top of the kick panel. I found a connector a grey one and a brown connector. The manual illustrates the use of a jumper. The manual doesnt say what color of connector or what wiring. Can anybody tell what connector? what color wiring? How many wires? My cel doesnt light on but i know there is something wrong with the car i own a ej if that helps. Is there an easier way to check.
FS
apexi vafc~new
215/40/17 cooper cobra
Honda foe life!
FS
apexi vafc~new
Honda foe life!
Re: how do u check for codes? (97itr86)
Foe real they have a obd1 scanner i thought they lend out tools only ill check it out.
Re: how do u check for codes? (poison)
i checked earlier i found a grey connector with 5 wires and a brown connecter with 2 wires its found next the glove compartment. How many wires are there suppose to be?
Re: how do u check for codes? (civic_type_r)
There will be a green rubber boot that has two connectors in them. One of them has three, the other has two.
Man dude i dont want to look like a dumbass but i dont see a green boot i even took off the glove box offand nothing would it connect to the ecu?
http://www.c-speedracing.com/faq/06.php
Its not always in a green boot, mine wasnt and i also had to pull the glove box to get to it. hope this helps.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_type_r »</TD></TR><TR><TD CLASS="quote">what color is yours?
sorry when i said its not always in a green boot it was kind of misleading. I meant the green boot is was not there.
Re: how do u check for codes? (SLATER97EX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLATER97EX »</TD></TR><TR><TD CLASS="quote">its this plug....
Yes thats the plug to check for codes......
Re: how do u check for codes? (axhandler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axhandler »</TD></TR><TR><TD CLASS="quote">Side note:
That's the same one you jump when you are adjusting the ignition timing.</TD></TR></TABLE>
Say what?? Never heard of this before...just thougth that was for checking codes??
Re: how do u check for codes? (Ricey McRicerton)
No you have to jump this connector when adjusting the timing or the ECU will readjust the timing at the same time you are. In other words if you change the position of the dizzy without the connector jumped then the computer will compensate and the timing will not change. There are several threads on the topic.
yep, get a paperclip and "jump" the connection, then count the flashes of the check engine light for the "code"...good luck!
damm dude i appreciate what everybody is doing but isnt that for a 97 civic ecu. i have a p28 that goes on a 94 civic ex. i dont have a green connector. thanx
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axhandler »</TD></TR><TR><TD CLASS="quote">No you have to jump this connector when adjusting the timing or the ECU will readjust the timing at the same time you are. In other words if you change the position of the dizzy without the connector jumped then the computer will compensate and the timing will not change. There are several threads on the topic.</TD></TR></TABLE>
This would be true. Not much people know this. You can also disconnect the battery or pull the ECU (PGM-FI), which is resetting the ECU, change the timing, then put it back in.
is the connector connected to the ecu where u have the harness or would i have to follow the wiring by glove box cause i only saw a brown and grey connector. thanx
Re: how do u check for codes? (SiFan)
i know i did i followed the manual and the connectors that it illustrates are not the same from the ones i see in my car. In the pictures it shows a grey connector with 2 wires. Mine doesnt have it or it could be located in another area. Ive even took the glove box compartment off and looked all around. Have u tried yourself did u find them. Let me know
