how do poorman type r run
i was thinking of doing a b18c1 bottom block with a b16 head w/b16 piston i was wondering how fast is it compare to a stock b16 or a b18c1 gsr?
Re: how do poorman type r run
i was thinkin of that but budget i cant afford to do so i sold my b18c1 head and got me a b16 head and i seen some cheap b16 piston on the the honda marketing for cheap should i buy it ?
ifeee, ifeee !!!! consider building it up not doing a cheep affordable job. you want power then you need to spend money!
I'm pretty sure even with the b16 pistons you will lose compression and make less power than a b16 or a b18c1... You would need to get some type r pistons...
b16 pistons & rods in b18c1 block with b16a head =5.43cr?
So at least get b18c1 rods and type r pistons and a 1 layer hg.
But still pretty dumb.
i recommend this build.... its my own
Car is street tuned on Crome, B18c block b16a1 head, bored to 85mm, benson sleeves, eagle rods, cp pistons, super tech valves and retainers, arp head studs and bolts and rod bolts, Integra Type-R manifold, sk2 tb, dc 4-2-1 header, b16 cams, Password JDM Carbon Fiber short ram intake, Ksport coilovers, Koyorad Aluminum Radiator, Chipped P28 ECU, Forza racing Exhaust, Hayame FR-1 fuel rail, 6 puck spring clutch.
i just to have a gsr block stock and a b16 head shaved and oversized valves and it ran good never blew up i was takin it till 11 grands ...
i think with a proper tune your engine set up would be closer power wise to the GSR than the B16
save up and buy some cheap used ITR pistons if you want a poor mans ITR.
But even with the ITR pistons you still lack the the goods that make an ITR worth anything to the aftermarket world
your missing
ITR tranny with LSD (most important)
highly sought after ITR cams (my favorite cam to boost and the only reason i have ITR anything)
ITR intake manifold....flows a little better than the b16
ITR header...your not gaining anything with that blinging ebay header
I have a JDM ITR and personally....it sucks. The only thing i like about an ITR swap is the LSD tranny and a good set of cams to boost later down the road. Hince the term Hype R
your missing
hmotors has CTR pistons for like 160 shipped or something like that. brand new, in box, with wrist pins.
I'd go with the CTR pistons on the B18C1 rods. It'll bump the compression up. Just make sure theres no piston to valve interference..
dude, im actually selling my 95 gsr head for $150.. the head dont come with dizzy,intake manifold,vtec solenoid,camshaft and cams.. valves and retainers etc in good condition.. i was going to do lsvtec on mine but decided to just stay stock cuz california smog suck *****... hit me up if wanna get
iono i just did a bunch of calcs on the ****. For a poor man's type R he would have to use CTR rods unless he used a GSR crank. Otherwise the CR would be too low. Unless hes talking about building an ITR in which case i was just not paying attention when I did my first calculations.
battle951sedan
19
01-19-2012 11:52 AM
