How do I seperate balljoints from the lower control arm?
Got the pin/nut off....but I can't get it apart.
I'm told I need some kind of puller or something......But I don't have one.
Is there any 'ghetto' way to do it?
Re: How do I seperate balljoints from the lower control arm? (hot_EG)
Make sure that the nuts are off...
Get a big hammer, like a 5-pound or something, and beat the hell out of the side of the lower arm, right by the ball joint. Be careful not to to hit the joint, and don't hit the arm like you want to break it, just really hard.
The arm should drop off the joint after a few hits. If not, get the puller...
Former Moderator
Re: How do I seperate balljoints from the lower control arm? (Revolveu2)
YES.
Beating the hell out of it is the way to go.
Don't use the "separator boots" because all they do is tear your balljoint boots.
Re: How do I seperate balljoints from the lower control arm? (B18C5-EH2)
Thanks guys....
Now I can't get the fawking axles out!?
I pry and pull and nothing!
Yeah just get a big *** hammer and hit right by the ball joint. Several solid whacks later you will see the seperation, or at least be able to feel it seperate when you hit it. Like he said- dont hit the ball joint!
Former Moderator
I sure hope you drained the tranny before you tryed getting the passenger side axle out!
ive changed 3 axles on my own car 1 on a prelude and one on a civic
ive never drained a transmission and NOTHING has ever come out.
Re: How do I seperate balljoints from the lower control arm? (KAMiN)
GRRRRRRRRRRRRR
Drivers side is done.
I've been working for 20 min trying to seperate the ball joint on the passenger side...it just WON'T budge.. I have the nut and cotter pin out!?
Is there some other way I can do it!?
put a jack on the rotor, make sure the jack is on the rotor only and nothing behind the rotor. Jack it up a little, then bang the **** out of the lower controll arm, always works for me with 2-3 hits...
Re: How do I seperate balljoints from the lower control arm? (dubnine)
DANGIT!
I've been going at this one ball joint for over an hour......it WON'T BUDGE!!!!!!
And in the process I've torn up the ball joint.
Wahoo
Wahoo
A pitmen arm puller would have worked way better than using the hammer. You can get this at sears or pep boys, I got mine at a freight harbor. The one the messes up the boot is a pickle fork.
Just rent the puller from autozone, like $22 and you get the money back when you return it. Also becareful not to strip the lower ball joint tread.
jojowasha
01-14-2007 01:49 PM
s-tech
08-06-2005 10:30 AM
y49crxsi
08-12-2004 04:45 PM
