how do i replace this bolt
Old 06-13-2006, 05:05 PM
3.point.2's Avatar
Default how do i replace this bolt
i need to replace the bolt being removed in this picture (taken from Behan's prelude tranny clutch install writeup).
it got messed up when i was taking my axles out yesterday. it doesnt appear to pop out to easily. thanks
Old 06-13-2006, 05:15 PM
95DxSi-R2
Guest
Posts: n/a
Default Re: how do i replace this bolt (h23eg)
there is a write up on breaking lower ball joints loose, myself, i just hit the knuckle with a hammer a few times and it pops loose. u should put the nut back on so u don't damage the threads.
Old 06-13-2006, 05:24 PM
3.point.2's Avatar
Default Re: how do i replace this bolt (95DxSi-R2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">there is a write up on breaking lower ball joints loose, myself, i just hit the knuckle with a hammer a few times and it pops loose. u should put the nut back on so u don't damage the threads.</TD></TR></TABLE>
i need to replace the bolt not break it loose, the nut wont go on. hitting it with a hammer is what mishaped it. found out about putting the nut on it about 15 minutes after it happened.
Old 06-13-2006, 05:26 PM
dumped4dr's Avatar
if u bent it ur kinda f**ked...
may need a new lower ball joint
(unless u can get lucky somehow)
good luck... hope someone can help u
Old 06-13-2006, 05:27 PM
95DxSi-R2
Guest
Posts: n/a
your fu*ked, get a thread chaser and try cleaning it up. that bolt is your lower ball joint.
Old 06-13-2006, 05:38 PM
3.point.2's Avatar
autozone sells lifetime warranty ball joints for like 30 bucks, think thats what im gonna have to do. next time ill use a picklefork...
Dren's Avatar
I agree, try chasing the threads. If that doesn't work you need a new ball joint.
Old 06-13-2006, 05:44 PM
95DxSi-R2
Guest
Posts: n/a
i did this a long time ago when i first started out. i ended up cutting the damaged section off with a hack saw, putt the nut back on and tightened it down, then drilled a hole threw the nut and ball joint. put a couter pin in and that was it. Still driving around with it, it's been 4 years.
Old 06-13-2006, 05:56 PM
C-bYE's Avatar
yep its a ball jonit, may be 30 bucks for joint, but it must be pressed in and that takes special tools. Next time DO NOT HIT THE BOLT!!!!!!!!!!!!! Hit the spindle whre it goes thru. Helps to put jack under the rotor, helps bust it loose(the bolt is tapered) that is why it is hard to get out.
Old 06-13-2006, 06:54 PM
Crx Jimmy's Avatar
Default Re: how do i replace this bolt (C-bYE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-bYE &raquo;</TD></TR><TR><TD CLASS="quote">yep its a ball jonit, may be 30 bucks for joint, but it must be pressed in and that takes <U>special tools</U>.</TD></TR></TABLE>
unless you call a hammer a special tool you might be special too, all you need is a hammer to get one in or out
Old 06-13-2006, 07:01 PM
3.point.2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by C-bYE &raquo;</TD></TR><TR><TD CLASS="quote">yep its a ball jonit, may be 30 bucks for joint, but it must be pressed in and that takes special tools. Next time DO NOT HIT THE BOLT!!!!!!!!!!!!! Hit the spindle whre it goes thru. Helps to put jack under the rotor, helps bust it loose(the bolt is tapered) that is why it is hard to get out.</TD></TR></TABLE>
haha unfortunately it wasnt even me who was doing it. it was a friend of mine. oh well now we both know what not to do
Old 06-13-2006, 07:29 PM
aak
aak's Avatar
since the threads are fucked anyway, use a hammer and the right size socket to beat it out. if it's got a snap ring make sure you remove that first. good luck.
Old 06-13-2006, 08:10 PM
wheelmanbg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95DxSi-R2 &raquo;</TD></TR><TR><TD CLASS="quote">i did this a long time ago when i first started out. i ended up cutting the damaged section off with a hack saw, putt the nut back on and tightened it down, then drilled a hole threw the nut and ball joint. put a couter pin in and that was it. Still driving around with it, it's been 4 years.</TD></TR></TABLE>
I did the same thing on my CRX a long time ago, never had a problem (sold the car 2-3 years after)
Old 06-13-2006, 08:22 PM
dthug's Avatar
Default Re: how do i replace this bolt (wheelmanbg)
yup you going to need a new ball joint...what were you tryin to do remove the nut?
Old 06-13-2006, 08:48 PM
AbitAvenger's Avatar
Default Re: how do i replace this bolt (dthug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dthug &raquo;</TD></TR><TR><TD CLASS="quote">yup you going to need a new ball joint...what were you tryin to do remove the nut?</TD></TR></TABLE>they took the axles out to drop the tranny for a clutch install
Old 06-13-2006, 08:58 PM
dthug's Avatar
Default Re: how do i replace this bolt (AbitAvenger)
all you had to do was take off that nut and bang the lca with a hammer then it comes right off
sonny0330
05-29-2008 06:53 AM
CAN97SH
04-13-2006 05:30 AM
CRseXy
13
01-10-2005 10:49 PM
EX-JAY
10-25-2004 02:46 PM
SC0TT
07-23-2003 05:21 PM
Quick Reply: how do i replace this bolt
