How do I remove my airbags
I am pareting out my del sol and everybody wants the air bags, how do I get them out with out a boom and a bad headache?
Re: How do I remove my airbags (madhatch)
follow the Helms manual... NOTE that all Airbag system wiring/connectors are YELLOW
1) disconnect battery
2) remove cover on sides of steering wheel
3) disconnect airbag harness on side/underside of steering wheel
4) using a Torx 30 Bit, (I think right size) remove a screw on each side.
5) lift airbag assembly (center section of steerign wheel) out.
6) be careful to move slowly so you do NOT pull any wires/connectors out.
7) done.
[Modified by owen_the_soyboy, 12:55 PM 8/23/2002]
7) done.
Re: How do I remove my airbags (owen_the_soyboy)
how about the passenger side?? the steering wheel one is easy but i'm trying to get out the passenger side to save weight as there isn't even a passenger seat. i tried to get it out tonight and failed, that bitch is really deep in there. so how bout some step by step for that one??? TIA
Re: How do I remove my airbags (ndogg)
im not exactly sure how it is set up on a civic but in know in a teg you can access it by taking the glove box out, so if you can get in down there, you should be able to unplug the conector and pull the couple of nuts holding it in
the big ragu
06-09-2002 12:01 PM
