How do i make my 2000 civic si faster?
hey guys, im new to honda so im trying to figure out what is up with my car. my si kinda lags when i release the clutch on first gear cause it wont grab until the clutch is almost released. i am having it repaired and adding a stage 2 clutch to fix this issue. what else can i do to make my si run faster. HELP!
Re: How do i make my 2000 civic si faster? (save3e)
Most people recommend some kind of intake (cold-air or short-ram), a decent header, and a cat-back exhaust.
The cheapest way to make good power is a turbo however...the parts listed above will give you a max of 10hp, but you'll have alot of extra noise
why did you even bother posting this? if you would of searched you would have found alot more topics regarding this then youll mosty likly get in replys.. but it all depends on you budget.. you can turbo it.. then theres. exaust. header.. (notice its not header"S"" as we only have one head.. then theres complete swaps..
Re: How do i make my 2000 civic si faster? (projekt-sol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projekt-sol »</TD></TR><TR><TD CLASS="quote">why did you even bother posting this? if you would of searched you would have found alot more topics regarding this then youll mosty likly get in replys.. but it all depends on you budget.. you can turbo it.. then theres. exaust. header.. (notice its not header"S"" as we only have one head.. then theres complete swaps..
He probably bothered posting because he's new to the site and new to Hondas in general.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projekt-sol »</TD></TR><TR><TD CLASS="quote">why did you even bother posting this? if you would of searched you would have found alot more topics regarding this then youll mosty likly get in replys.. but it all depends on you budget.. you can turbo it.. then theres. exaust. header.. (notice its not header"S"" as we only have one head.. then theres complete swaps.. </TD></TR></TABLE> How much you got to spend?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projekt-sol »</TD></TR><TR><TD CLASS="quote"> then theres complete swaps.. </TD></TR></TABLE>
since he's got an Si, it'd probably be retarded for him to swap put the B16 at this point, unless it's ready to blow.<<Even if that happened it'd still be more worth it to build that instead of swapping in a GSR, which a lot of people seem to want to do.
well i do know that turbo is the fastest way. i was looking into a type r camshaft and also the gears to be changed out because my brother tells me it actually boosts up the revolutions. im still researching about my car and it is quite interesting. i was looking online and just found out that "vtec" burns motor oil. how can i prevent that?
First of all, it won't really get that much faster without nitrous, or turbo. There really is no reason to waste your money on a stage two clutch, your car doesn't need it. Go with an exedy stage 1, not that expensive and will handle what you have. Just make sure you save and do it right the first time.
Re: (broke91hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by broke91hatch »</TD></TR><TR><TD CLASS="quote">First of all, it won't really get that much faster without nitrous, or turbo. There really is no reason to waste your money on a stage two clutch, your car doesn't need it. Go with an exedy stage 1, not that expensive and will handle what you have. Just make sure you save and do it right the first time.</TD></TR></TABLE>
get a exedy stage 1 or act stage 1...dont waste your money bro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by save3e »</TD></TR><TR><TD CLASS="quote">well i do know that turbo is the fastest way. i was looking into a type r camshaft and also the gears to be changed out because my brother tells me it actually boosts up the revolutions. im still researching about my car and it is quite interesting. i was looking online and just found out that "vtec" burns motor oil. how can i prevent that?</TD></TR></TABLE>
also just cause u change cams and cam gears, doesnt mean u get more RPM.
and as far as VTEC burning oil, u can prevent that. its just what happens. It not like it eats the oil or anything. Just a lil hear and there if your motor is in good shape.
Re: How do i make my 2000 civic si faster? (Malakai)
ok so stage 1 is good enough. i checked on ebay and exedy clutch 1 runs 3 hundred. is stage 1 going to last longer or will stage 2. see the problem why im changing my clutch out is because the release from 1st to 2nd gear is lagging. like i wouldnt get a response from the clutch until its almost released.
Stage 2 is just overkill for what you have. I have I/H/E and intake manifold on mine and my stage 1 exedy works perfectly. Just remember to resurface the flywheel when you do it. And to increase your rpm range, you need to get a set of cams that are effective in that high range, then change your valve springs and retainers.
I put an ACT Xtreme PP and SS disc in my car, but I wanted something where i wouldn't have to go and buy another clutch if I upgraded anything in my engine. That and I thought that having a "heavier duty" clutch meant "slower" wear on the clutch with a basically stock set up. Seems to have worked, i put about 60k on the clutch and couldnt really tell if it wore down much when I pulled the trans off to have it rebuilt. But hey, to each his own.
