How do i install greddy oil catch tank????????????
I just got a catch tank for my del sol and have a few questions. Its an sohc non VTEC. Doesnt one tube run from the catch tank to the fitting on the back left corner of the valve cover, and the other go from the catch tank to fitting on the intake tube? If so my problem is that the intake pipe with my Drag Gen 3 kit has no fitting.
Re: How do i install greddy oil catch tank???????????? (BoostedD15B7)
Out from PCV valve goes into "IN" of GReddy tank, then "OUT" from GReddy tank goes to intake manifold where PCV valve exit hose used to go. Nothing to do with the intake pipe and the valve cover.
HTH!
Steve
HTH!
Steve
Re: How do i install greddy oil catch tank???????????? (stevecockrill)
it doesnt specify in the directions which is in and out on the tank so im assuming it doesnt matter. So basically you just splice it between the pcv valve and the fitting on intake? Also how do you empty it. Do i need to mount it where i can take it out easily to empty it? How long does it take before i would see some on the view tube?
Right, I forgot, the GReddy isn't "directional". Its a good idea to stuff some steel wool in the unit to help condense the oil too. Remember intake MANIFOLD not just the intake tube.
Also, there's a how-2 on the c-speedracing website....
http://www.c-speedracing.com/howto/c.../catchcan.html
I haven't installed mine yet (damn, too much crap in the way!!) so I don't know how long it takes to "fill". Yes, you need to be able to remove the can, or use the drain plug to empty it.
Steve
Steve
crxsiperf
06-01-2005 11:03 PM
Grip
06-15-2004 05:43 AM
