how do i ground spoon spark plug wires?
hi i just bought some spoon spark plug wires and dont know where to ground them. i wrote the guys i bought them from and thay said just ground them some where under the spark plug cover. but where? the only place is one the the four bolts that hold on my valve cover on under my spark plug cover is this the right place to ground them? and if thats the right place do any of you happen to know how many ft.lbs of torque that those bolts tighten to? because i dont have a service manual. by the way i have a b18c1 engine.
Thanks.
Thanks.
Thanks alot everyone! see this is why i love honda-tech.com very quick replys and theres people that know what thay are talking about unlike some other sites. thanks very much
hey i put the wires on but i dont know if the bolts under the spark plug cover is a good spot because there is a little plastic washer thing at the bottom of the screw that doesn't seem to come off so i dont know if it would be a good connection. any ideas? do you think that it would be a good connection just touching the screw? or do i need to connect it on the outside valve cover screws?
Modified by matt56 at 8:31 PM 3/18/2006
Re: how do i ground spoon spark plug wires?
I grounded mine to front of the head underneath where the valve cover meets the surface there a hole for a 14mm bolt works for me u just gotta mod ur spark plug cover to let the grounds threw or just don't use one
