how do I get the gauges out of my dash?!?!?!
I'm trying to get the gauges out of the dash on my eg. I can't figure out how to remove the trim in order to access the gauges. I got the two bolts on the trim obviously, but I can't find anymore. I feel stupid as heck for asking this question, but I'm going crazy. HELP!!!!!
Re: how do I get the gauges out of my dash?!?!?! (743)
You have to pop out the black dash piece. Its the peice that the vents and clock sit in. You should be able to access it from there. I just pulled my entire dash out to do mine.
-Jake
-Jake
Pull the bezzel straight out towards you (grabbing it towards the bottom). There are two tabs on the bottom side of if holding it into the dash. There is no need to remove the dash trim with the vents etc on it.
-a
-a
Re: how do I get the gauges out of my dash?!?!?! (Achenar)
There is a hidden screw under where the emergency flashers button is...
You have to get it out to see it and take it out...
It may be whats holding you up...
I guess you got the two screws from under the front section...
