How do I change out my IACV?????
Ok I just got a new IACV b/c my idle is all wack but I don't know where the IACV is located so I can't replace it. Can anyone post pictures on how to change out the IACV or give a detailed how-to???? My car is a 94 civic with a JDM gsr motor. (I already searched).
https://honda-tech.com/zerothread?id=878371 is the only search result I came up with and it wasnt detailed enough. Thanks in advance everyone! https://honda-tech.com/forums/images/smilies/emthup.gif |
Re: How do I change out my IACV????? (Chris M)
bump i really need some help quick....im tired of driving the car while its running this crappily!!!
its on the back of the intake manifold u cant miss it if you know how it looks like lol its either 10mm or 12mm screws i forget which. but on the d16z6 it was 2 screws and two lines underneath for soem reason coolant came out of one and the car was hot it was all bad but i was wearing gloves cuz i was working when the car was hot. damn that shit got all over the gloves so damn hot almost burned my hand i took off the gloves helal quick. just make sure its a little cold before taking it off.
it looks like a cylinder thingy just search around here ill search around for u and give u a pic. |
Re: (zad5)
http://www.imagestation.com/picture/...d/f7cff66e.jpg
http://www.newbieforces.com/files/ia...----------.jpg http://www.newbieforces.com/files/iacv.jpg http://www.newbieforces.com/files/on%20intake.jpg the blue thing http://www.integra.orcon.net.nz/iacv1.jpg all from seraching gave u more then one cuz if the stie goes down u know wut im saying search better next time. |
Re: (zad5)
ok the new one is now on but my next question is, how do i take the throttle body off? when the iacv first went bad we took the throttle body apart and plugged up one of the holes but now i need to unplug it since i got the new iacv on but now i forget how to take apart the throttle body.
Re: (Chris M)
bump for a quick answer...the car is in my driveway and it looks like it is getting ready to rain so i need to fix this quick.....so far i have the top two bolts of the TB off, unplugged all of the hoses, unplugged the map and now im stuck with the throttle cable but it still seems like it doesnt want to budge....is there any hidden bolts or screws anywhere else that i havent found yet? this seems so much more complicated than i know its supposed to be http://images.honda-tech.com/set1//smile/emcrook.gif
it's usually located around the intake manifold either in the back or front. but for the gsr i'm not sure where it is but look around the intake manifold https://honda-tech.com/forums/images/smilies/emthup.gif
Re: How do I change out my IACV????? (Phantastic)
There's a total of 4 mounting bolts/studs. Probably two bolts and two nuts you have to take off.
To get the cable off, open the throttle on the throttle body wide open and use the slack in the cable to get it disconnected. |
Re: How do I change out my IACV????? (Marauder)
ok i have EVERYTHING disconnected that i can see.....im just going to start prying at it i guess http://images.honda-tech.com/set1//smile/emcrook.gif
Re: (Chris M)
WAT THE PART NUMBER FOR THE IACV GASKET
