How do I adjust the valve clearances on a JDM B16a engine? - Honda-Tech - Honda Forum Discussion
Old 01-31-2011, 09:55 AM   #1
TheJakePatty's Avatar
Default How do I adjust the valve clearances on a JDM B16a engine?
My grandpa called the valve clearances "lashes" and I need to check it with a gapper. First off what are the numbers? secondly are they the same for intake/exhaust valves? I'm also not really to sure what the hell he is really talking about. any help/insight would be nice. thanks.
TheJakePatty is offline   Reply With Quote
Old 01-31-2011, 09:59 AM   #2
Default Re: valve clearances?
Mentioning the engine might help.
Former User is offline   Reply With Quote
Old 01-31-2011, 10:04 AM   #3
jdm B16a
Old 01-31-2011, 10:12 AM   #4
The diagrams below show how to set the valve lash on a B16a2 engine (not sure if JDM B16a engine is the same).
Old 01-31-2011, 10:24 AM   #5
Default Re: How do I adjust the valve clearances on a JDM B16a engine?
Thanks very much, i'm sure they can't be to much different.
Old 01-31-2011, 10:37 AM   #6
Mr. EG's Avatar
no its extremely easy. use vise grips on a socket while using your flathead screwdriver to adjust the "lash"
Mr. EG is offline   Reply With Quote
valve to valve clearance skunk 2 pro 2 cams Honda-bond All Motor / Naturally Aspirated 32 01-22-2011 03:45 PM
valve clearance gsr gsr96cx Acura Integra 2 08-25-2008 07:11 AM
What header should I get for best ground clearance? B SERIES JDM_sedan Tech / Misc 3 08-07-2005 08:08 AM
Clearances???? HotRodTeg All Motor / Naturally Aspirated 1 11-17-2003 07:26 AM
Valve adjustment clearance for intake and exhaust? HELP! HybriDNA Tech / Misc 5 01-06-2003 10:01 PM
Tags
adjust, adjusting, adjustment, b16, b16a, b16a2, civic, clearance, jdm, lash, motor, screwdriver, socket, valve, valves, vavle
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
Question Title:
Description:
