how do I add transmission fluid on manual tranny?
I just drained it, changed the axles, but them all back on......now how do i add more tranny fluid. I know there is that filler bolt.....do I add it there? if so how? its horizontal???
Re: how do I add transmission fluid on manual tranny? (civcexcoupeblack)
its directly behind the axle, you need a tube of some sort, i jam the tub in the hole then fill from above the engine bay.
Re: how do I add transmission fluid on manual tranny? (C5_ALLMOTOR)
C5_ALLMOTOR......you pull the speedo gear? Is that such a good idea? Had anyone else done this? How do you know when it is full if you do it that way.
[Modified by 96HatchB18, 5:28 PM 9/22/2002]
shadohconspiracy
13
11-04-2007 08:32 AM
