how to clean cold air intake filter?
how do you clean cold air intake filter? What kind of oil are you suppose to real apply?
theres a K&N 'clean and oil' kit?
H-T White Ops
Re: how to clean cold air intake filter? (yh23)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yh23 »</TD></TR><TR><TD CLASS="quote">theres a K&N 'clean and oil' kit?</TD></TR></TABLE>
Are you asking or are you telling us this?
If you're asking....yes, there is. Autozone for less than $10.
If you're telling us......well......tell us something we didn't know.
Re: how to clean cold air intake filter? (DJ_SaNdOz)
I clean my K&N cone with simple green, a medical scrub brush, and water. I clean it, dry it and then re-oil it and it's good as new.
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yh23 »</TD></TR><TR><TD CLASS="quote">K&N filter cleaning/charge kit. $10 @ autozone?
will do!
thanks!</TD></TR></TABLE>
That right there tells me you already knew what the hell it was. You just wanted to make a thread to get some more posts added to your count.
will do!
I just gotta cheap ebay filter, so I spray it down, dry it off, and oil the beast back up an its good to go
Id hate to scrub it with any chemicals or anythin cause it might fall apart lol...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yh23 »</TD></TR><TR><TD CLASS="quote">how do you clean cold air intake filter? What kind of oil are you suppose to real apply?
theres a K&N 'clean and oil' kit?</TD></TR></TABLE>Thats it. I use WD40 on foam air filter elements in power tool engines. They must be similar sprays. You soak the element and squeeze or rinse out the sludge.
does anyone know if you can buy just the K&N (fram makes some too now) oil I hate using the normal cleaning stuff that it comes with because using the pump style sprayer takes forever. I use simple green and it works GREAT.
Re: (Slow_CvC99)
parts washer is fine, but your not suppose to use compressed air since the pressures are so high, you will leave very small tear marks in the filter media unless you have one of those completely metal filters like the blitz one? (forgot who made the all metal one)
Re: (yh23)
does drying K&N style filters with a hot blowdryer damage the filter??</TD></TR></TABLE>
to answer easily, no. think about people that are using short ram intakes, the temo under the hood is far hotter than what a blow dryer can do to it, i think it will be just fine
Re: (asmallsol)
I picked up one of those K&N filter recharge kits.
I washed filter with the cleaner solevent, rinsed it with tap water, then i stuck it in the washing machine and put it on SPIN DRY. drained all the water out, then sprayed it down with the K&N filter lube.
one question though, I dried my CAI filter with a BLOWDRYER before...
kcari
Honda Civic (2001 - 2005)
10
08-06-2007 08:38 AM
noltofan69
01-01-2006 03:24 PM
