how can i tell?
how can i tell?
my friend just bought a 97 del sol, but the back sticker telling which model it is has been removed. i was wondering how i can tell which model it is by lookin at the engine. its not the si because the engine is sohc. any help would be appreciated
cute little bastard
Re: how can i tell? (kydoster)
Write down the VIN, go to http://www.carfax.com, it'll tell you what trim at least.
Re: (kydoster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kydoster »</TD></TR><TR><TD CLASS="quote">there is nto a del sol with a dohc vtec engine?</TD></TR></TABLE>
Del Sol VTEC has a B16. A B16 is a DOHC VTEC Engine.
Re: (Chong)
thats what i said in the begining, i thought maybe i was misunderstood....i know it is not a si so that only leaves the s and base mdoel....is there not a number somewhere under the hood? somehting that tells the engine type?
You said the sticker has been removed, and that the engine is a SOHC.
Therefore IT CANNOT be the DEL SOL VTEC.
Which leaves the S and the Si. Look under the hood, and compare with the pictures posted above.
Re: how can i tell? (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">The Del Sol Si has a sohc.
S - D16Y7 (note the airbox behind the valve cover)
Si - D16Y8
VTEC - B16A2
I actully thought the S had the d15b7 (for a while a while anyway) ang the Si had the d16z6. I didn't think the Del Sol had the d-y series of motors.
Si - D16Y8
VTEC - B16A2
not trying to be an asshat-they could have had a b16 in there and blown it up. then put a d in to sell it. go with the vin. more accuracy if you dont know what your looking at or for.
Re: how can i tell? (TulowSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TulowSi »</TD></TR><TR><TD CLASS="quote">i thought,
S-D15b7?
Si-D16z6
VTEC-B16a3</TD></TR></TABLE>
those were the early models
93-97 U.S. spec Del Sol's...
93-95 (OBD1):
Del Sol S - D15B7 SOHC non-VTEC - 102hp@5900rpm 98tq@5000rpm
Del Sol Si - D16Z6 SOHC VTEC - 125hp@6600rpm 106tq@5200rpm
94-95 (OBD1):
Del Sol VTEC - B16A3 DOHC VTEC - 160hp@7600rpm 111tq@7000rpm
96-97 (OBD2a):
Del Sol S - D16Y7 SOHC non-VTEC - 106hp@6200rpm 103tq@4600rpm
Del Sol Si -D16Y8 SOHC VTEC - 127hp@6600rpm 107tq@5500rpm
Del Sol VTEC - B16A2 DOHC VTEC - 160hp@7600rpm 111tq@7000rpm
and he states its a 97.. good **** bauley
S-D15b7?
Si-D16z6
93-95 (OBD1):
94-95 (OBD1):
96-97 (OBD2a):
Re: how can i tell? (e gee two)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by e gee two »</TD></TR><TR><TD CLASS="quote">
and he states its a 97.. good **** bauley </TD></TR></TABLE>
Oops.....reading while on pain meds OWNZ ME LOL. I did not even notice the statement about it being a 97.
be professional
Re: (kydoster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kydoster »</TD></TR><TR><TD CLASS="quote">i know it is not a si so that only leaves the s and base mdoel</TD></TR></TABLE>
You're confused. There are only 3 trim levels of del Sols in the US:
- S
- Si
- VTEC
The S is the base model and comes with a SOHC non-VTEC engine (D15B7 in '93-95 models, and D16Y7 in '96-97 models).
The Si is the mid-range model and comes with a SOHC VTEC engine (D16Z6 in '93-95 models, and D16Y8 in '96-97 models).
The VTEC is the top-of-the-line model, and comes with a DOHC VTEC engine (B16A3 in '94-95 models, and B16A2 in '96-97 models).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">is there not a number somewhere under the hood? somehting that tells the engine type?</TD></TR></TABLE>
Yes. The engine code is stamped onto the front of the block, right next to where it mates to the transmission bell housing (to the left of the exhaust manifold).
- S
- Si
- VTEC
Risky Business
Re: (kydoster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kydoster »</TD></TR><TR><TD CLASS="quote">it is a 97 and im outa town so i cant check the f*n vin</TD></TR></TABLE>
Why don't you read my ******* post. I even posted pictures so that you could easily identify what motor is in the car. Look at the car, and then look at the pictures I posted. It's not that ******* complicated.
Re: (Targa250R)
Why don't you read my ******* post. I even posted pictures so that you could easily identify what motor is in the car. Look at the car, and then look at the pictures I posted. It's not that ******* complicated.</TD></TR></TABLE>
obviously if he cant check the vin he cant check the motor
reading owns
reading owns
Re: (ZipTieGuy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fat Skoundrel Jr. »</TD></TR><TR><TD CLASS="quote">Write down the VIN, go to http://www.carfax.com, it'll tell you what trim at least.</TD></TR></TABLE>
CarFax is Bullshit. When I ran my VIN for my EM1 it said my car is a SOHC Vtec..... Are they fuking SERIOUS?!
