how to bleed my slave cylinder?
Old 03-28-2004, 01:48 AM
rtiadnoh's Avatar
Default how to bleed my slave cylinder?
my fluid was out for my clutch so i filled it up but it still sticks once in a while. i was told to bleed the slave cylinder or something like that to get the air pockets out. how do i do this. i have b16 transmission.
Old 03-28-2004, 03:58 AM
StreetwizeRacin2's Avatar
The slave is located on the front of the transmission case, to the left of the lower half of the exhaust manifold. To bleed it, depress the clutch a few times (let the hydraulic pressure build up a bit). I believe it is a 10 mm, I may be wrong. Break the nut at the tip of the slave loose in a QUICK manner, the fluid should spray out due to all the pressure built up inside. Do this 3 or 4 times to make sure all the air is out of the system. Air in the hydraulics can make the world of a difference!
hitop
08-13-2015 10:34 AM
hawtsoss
10-30-2008 07:01 PM
Tegraracer90
03-10-2008 12:55 PM
Dool_Ohver_Hed_Cam
07-03-2007 06:01 PM
bradwcampbell
03-26-2002 04:11 PM
Quick Reply: how to bleed my slave cylinder?
