how to adjust toe in rear
Re: how to adjust toe in rear (95sloweg)
Yup getting a pro to do it is the best idea
but if you wanna do it yourself as a quick fix or whatever then what you need to do is
look for the wee arm that connects the front of the trailing arm to the body, there will be a bolt though it with a nut on the end if i remember right
loosen that bolt off and youll be able to move the arm, this will adjust the toe on the wheel
once youve got the wheel set how you want it you just tighten that bolt back up (bloody tight) and you should be set
Re: (oneslow eh2)
Cool, once youre underneath it should be easy to see what you need to loosen off etc
but i wouldnt leave it as a permanent thing, would definatly get an alignment as soon as possible
project-boosteD
Suspension & Brakes
01-27-2009 01:58 PM
jdurston
Suspension & Brakes
02-19-2006 08:07 AM
