Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Honda Civic / Del Sol (1992 - 2000) (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/)
-   -   How to adjust the a/c belt tension (https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-adjust-c-belt-tension-2023836/)
joeEK00EX 06-24-2007 08:09 PM
Hey well I have a problem with my D16Y8 it makes a noise when I turn on the A/C in my 00 EK EX so I'm guessing is my ac belt how do I tighten it up can you guys help? TNX
tech8 06-24-2007 08:49 PM
Re: How to adjust the a/c belt tension (joeEK00EX)
The noise you are hearing is not a growl, right? If it is, it may be a bad A/C Idler Pulley Bearing. Here is a TSB:
http://www.tegger.com/hondafaq...e.pdf
But, to answer your question on how to adjust the A/C belt tension:
(Use the image in the TSB as a guide, so you know which is the pulley center nut, and which is the adjusting bolt.)
1. Loosen the center nut on the pulley (Loosen, don't remove).
2. Turn the adjusting bolt to get proper tension.
3. Re-tighten the center nut on the pulley.
joeEK00EX 06-24-2007 11:23 PM
Re: How to adjust the a/c belt tension (tech8)
Hey thanks bro preciate noise is gone. http://images.honda-tech.com/set1/smile/emthup.gif
