hot tanking head
hot tanking head
My other z6 head came in today. It's pretty caked with oil as it seems. The guy I bought it from says that the motor spun a bearing so the head is still good. Just needs to be hot tanked. What do I need to do to get the head ready to be hot tanked?
here's some comparison pics for my other z6 head:
Re: (civiccpedx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx »</TD></TR><TR><TD CLASS="quote">is the valve job required to get the head tanked?</TD></TR></TABLE>
No. I'm having my rocker arm assembly and cam caps hot tanked.
Re: (Cuong-nutz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cuong-nutz »</TD></TR><TR><TD CLASS="quote">what do you mean by valve job?</TD></TR></TABLE>
As in your valves are bent because they arent even seated to the head. Your valve guides are definitely fucked. You need to take that head to a machine shop.
official honda whore
Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">
As in your valves are bent because they arent even seated to the head. Your valve guides are definitely fucked. You need to take that head to a machine shop.</TD></TR></TABLE>
actually the cam is still in that head so #2 and#3 valves should be out, but it does look like the #4 exhaust valve isnt seated all the way
why did you buy this head when your better off just fixing your old head and then you would have a fresh head with fresh seals
take it to your local machine shop, order a complete gasket kit for the head including head gasket and have them do a valvejob and clean up the head
they will install new valve seals guides etc and will be able to tel you all the problems like if you need a new valve(s)
i never understand why someone would buy another head if theres is easily fixable for cheap and they will have a nice fresh valve job and seals
brian
brian
Re: (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer »</TD></TR><TR><TD CLASS="quote">
Trust me the head is fucked. Serious machine shop work. You should have used your old head and saved yourself some money.
Re: (civic_speed99)
Im having my rocker arm assembly (shafts, arms, cam caps), throttle body and valve cover all hot tanked, then having the TB and valve cover bead blasted for about $50 bucks. Seems the going rate is about $35-40 per load. I only asked around at a few places but they can only fit so much "stuff" in there at once. Keep in mind its large enough to clean a full engine block, so you can probalby fit alot of odds and ends in there.
Re: (civic_speed99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_speed99 »</TD></TR><TR><TD CLASS="quote">How much does hot tanking cost. I need to do this with my new head.</TD></TR></TABLE>
Hot tanking isn't that expensive. You will need new valve seals and still need to assemble the head though. You are looking at some cash then.
Re: (TeStUdO)
Hot tanking isn't that expensive. You will need new valve seals and still need to assemble the head though. You are looking at some cash then. </TD></TR></TABLE>
I can handle the assembly part.
Re: (civic_speed99)
aww ******* aye gonna spray it down and see how bad it is.... I'm currently working on a mini-me project so I bought two heads.
Modified by Cuong-nutz at 9:22 PM 3/21/2005
