horse power
horse power
just pick up a 98 civic hatch.
the motor inside is a d16y7 with just header and intake. right now i consider it slow. i dont want to swap the motor but i want more power what can i do??
also does running a chipped computer make a big difference??
Re: horse power
You have a non-VTEC economy motor. There isn't anything you can do to get more power. You can bolt on all sorts of crap that will just make your car louder. The only option you have is at least a head swap. Look in the FAQ for a mini-me swap. That's just swapping a head/intake manifold from a D16Y8 to convert it to VTEC. After that, you can put together a homemade turbo kit and boost it. That's the only way you are going to get any power out of it without swapping to a B-series.
The Grumpiest
Re: horse power
Head swap and you're still slow. Boost or swap. Look at section #4 in the FAQ's. A chiiped ECU on one of these is just wasting your money. This aint the F&F.
Re: horse power
k series is a big investment... i was looking to get power with out spending so much.
where can i get an upgraded ecu if i wanted one?
ohhh one time i drove my brother in laws honda eg and i redlined pass 9 grand. how can i do this?? i have a redline at line at like 6.
The Grumpiest
Re: horse power
K-series are some of the most expensive swaps out there there right now. Definitely NOT as easy a swap as a B-series. Check out k20a.org for builds and parts lists.
As for the redline maybe you should ask your brother-in-law what he did?
Re: horse power
thats all so true... thats why i was thinking of keeping the stock motor in so good on gas.
after reading up on the mini-me swap im getting some inspiration...natural that is.
on a scale of one to ten hows the difficulty level of the head swap??
also do i need a p2p ecu if i swap the heads??
and will i need to change my fuel control??
Re: horse power
-depend how mechanically incline u are... ir u know what ur doing it a 2 on the difficult scale,,, if u dont know what ur doing it a 10... all depends
- i would just get a chipped ecu from pherable.net
-and dont really know what u mean by "changingfuel control"...
Re: horse power
wanna rev past 9 grand, build the motor. the whole motor. and the fuel pump needs to be replaced as well. and clutch. stock EM1 fuel pump is good for 8500 with big cams. 8000 on a 65 shot of nitrous just for an example.
Re: horse power
1 Post
Re: horse power
so why does these type question come up here often? you can head swap, intake manifold swap, bolt ons, any kind of boost will give you more horsepower. why you need horsepower? Follow these steps and you will learn a lot. Search, rear, re-read, re search, read, validate, do
leondx
10
03-07-2010 12:36 PM
275Performance
04-30-2003 05:22 PM
