Horn doesn't work on my 2000 Si
I checked the fuses so that's out the way....what next? Any shop diagrams or tips would help. Thanksfully I just got the car inspected but I'd like to have my horn working lol
Re: Horn doesn't work on my 2000 Si
Does the horn sound when directly wired to the battery?
Bad clock spring in the steering wheel? |
Originally Posted by RonJ@HT
(Post 43745194)
Bad clock spring in the steering wheel? Thanks. |
I would find that gray single wire pin connector under the dash and see if it'll honk by disconnecting the connector and remove the insulator by half inch or so on both end of the wire you founld and plug in that wire you found laying around to the gray wire connector and touch the other end to ground to see if the horns goes off.
Originally Posted by nus_dogg
(Post 43745433)
