Hooking up extra cooling fan...how should i do it?
My friend gave me one of his old stock prelude fans. I only have one fan now and a blank spot on other side. I was planning on using this new fan for extra cooling, and just run it all the time. Where is the best place to tap the power into. I want it to come on when i crank the car and run constanly.
Re: (BoostedD15B7)
On my 240sx when I wnated to have two fans running ALL the time....I wired one to the negative battery post and the other was tapped into something tht comes on with the key beng turned over. I personally used the feul pump fuse......
Re: Hooking up extra cooling fan...how should i do it? (BoostedD15B7)
well what you want to do is pointless unless you swap fans the fan on the prelude has more cfm. but don't even bother its poinless
Re: Hooking up extra cooling fan...how should i do it? (scratchy)
Put a relay on it or enjoy watching your car burn to the ground. Just wire a relay onto the large black and yellow wire on your dizzy.
Re: Hooking up extra cooling fan...how should i do it? (b16matt)
more info please... One says that is pointless to use the prelude fan, and the other says car will burn. Please, a little more details.
Re: (pdiggitydogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">why not just make connections off the stock fans wiring? Then it would turn on w/ the stock fan</TD></TR></TABLE> this is the best idea so far
Fuster_Cluck
04-19-2003 05:37 PM
