hood wont close
Old 08-11-2003, 01:23 PM
Wazup's Avatar
Default hood wont close
i used to slam my hood to close it, now my hood wont close all the way. it locks into the safety latch, but it wont any further than that.
anyone have this happen? what can i do to fix it?
Old 08-11-2003, 01:31 PM
DubbleD's Avatar
Default Re: hood wont close (Wazup)
my friend's eg use to do this. he got a screw driver and jus bent some **** around.lol i dont kno how the hell he fixed it but he did....i suggest you jus find someone parting their car out or goin to a junkyard. good luck
Old 08-12-2003, 01:19 AM
94LsEgHatch's Avatar
could be 2 things.
check underneth your radiator to see bent or pushed up. if it is you need to get your radiator support pulled down.
if it is straight then you need to get a new hood latch or you can bend it back into place. i suggest getting a new one. good luck!
Old 08-12-2003, 11:22 AM
photec2's Avatar
Default Re: hood wont close (94LsEgHatch)
i just kick mine a couple of times
Old 08-12-2003, 11:31 AM
dAng!
Russ713's Avatar
Default Re: hood wont close (photec2)
adjust the position of the locking mechanism next to the radiator. You can loosen the bolts and slide the mechanism higher up until it's high enough to secure the hood properly.
It's also possible part of the mechanism is bent. Close the hood until the safety latches. Lift the hood without releasing the safety, and look at where the latch is sitting. Make sure everything is lined up correctly.
Old 08-12-2003, 09:27 PM
built562's Avatar
Default Re: hood wont close (Russ713)
im prettyr sure its the mechanism, over time it has moved down out of position, just get a 10mm socket and loosen the bolts and slide it straight up a very small amount, make sure to keep it straight or the hood will close crooked.
Old 08-12-2003, 09:37 PM
viet's Avatar
Default Re: hood wont close (akumaracer)
yeah, its the hood latch. Loosen then three screws, and move it up. Make sure everything is straight, tighten it, then close the hood. It could also be your hood latch spring. It could be broken.
mandoski
10-07-2018 12:47 PM
95-del-sol
Paint and Body
07-23-2013 02:41 PM
ej6kevin515
01-23-2012 07:24 PM
ComeOnKip
02-06-2009 12:57 PM
silver_nteg
09-05-2004 08:03 PM
Quick Reply: hood wont close
