HONDATA. Need a pic/Diagram. ASAP
Fellas, If someone knows which wire goes where, it woudl be greatly appreciated. My car got robbed and they ripped those wires out of the 4 prong connector on my hondata
I need either a diagram, from the manuel, or just a close up pic. I am going to re soilder those in.
The car should start and run just not get on it. Call Jason @ Autologic (Stoopidfast) and get one it isn't that much money. Also how did that happen it looks like a clean cut..
Re: (Rico)
I didnt post the whoel story. But I got robbed. Someone broke into my car in front of my house. cut my alarm, my battery. took My tach, speakers, sub, amp. Everything.
They did not take my Hondata, why? i have no idea. but they ripped those wires out of it. I think they may have thoguht it had somethign to do with my alarm or something.
But yeah, you think i can buy just new wires then?
Re: (93turbo16)
No, i just re hooked up my battery and everything, My car wont start. it tries, but doesnt. I need to get that plug or a picture or something, i rig something up
Re: (athoughts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts »</TD></TR><TR><TD CLASS="quote">No, i just re hooked up my battery and everything, My car wont start. it tries, but doesnt. I need to get that plug or a picture or something, i rig something up</TD></TR></TABLE>
If you have stock injectors, you can remove the chip and it should start.
Re: (93turbo16)
when i remove it, i will just be running straight stock ecu correct, it wont be completly untuned?
No info will be lost to remove the chip and put it all back in once i get my wires fixed. ?
Re: (athoughts)
I have no BIG CHIP on mine. I have a p28.
the only thing i see is the hondata plug that goes directly into the ecu. if i unplug that will it work? run as stock?
Re: (athoughts)
You have to have a chip in it if you have hondata.
If you want the ecu to run like stock, just cut J1. That is a jumper that makes the ECU read the chip. If you cut it, it will be a stock ecu.
BUt I think you should just get a new harness or fix the one you have. Give hondata a call for a diagram maybe?
Re: (93turbo16)
yeah i have one. but not a big one where i reconize it to remove it.
I just unpluged the hondata all together, it started. started with a CEL, and its not fking working properly to let me check the code.
expletive theives. all these problems for no reason.
Ill take pics of inside the ecu tomarrow sometime when its day time.
Its real hard to work at night, and i only have 1 arm. i have a broken collar bone
Re: (athoughts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by athoughts »</TD></TR><TR><TD CLASS="quote">yeah i have one. but not a big one where i reconize it to remove it.
Its real hard to work at night, and i only have 1 arm. i have a broken collar bone </TD></TR></TABLE>
Yea without the chip it will run in limp mode with a solid check engine light.
Shitty about the broken collar bone.
Re: (SVOboy)
I dont want to cut anything, beacuse driving it on the stock ecu is temporary.
I need that wire in my above pic. danm thieves ripped it out
Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy »</TD></TR><TR><TD CLASS="quote">It's just a small wire, it's not stock, you can reconnect it with a second of soldering.</TD></TR></TABLE>
He thinks that the creater of this thread stole the hondata and hes asking how to work it again
Re: (DohcSide)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mluckxxx »</TD></TR><TR><TD CLASS="quote">sounds fishy.</TD></TR></TABLE>
sorry wrong quote
sorry wrong quote
