honda crx delsol - CHECK CODES
honda crx delsol - ENGINE CHECK CODES ( CEL )
Hi, Can anyone help. I own a honda crx delsol (jap import) 1992. The check light is always coming on and I cant get it checked in my honda gargage (uk) as it is an import.
I have tried doing it manually by jumping the ecu wires and counting the flashes to decifer the code but it doesnt stop flashing.
Can anyone help?
Dave
Modified by saunders400 at 8:01 AM 8/13/2007
Can anyone help?
Dave
1 Post
Re: honda crx delsol - ENGINE CHECK CODES (saunders400)
It will continue to flash the code over and over as long as that jumper is plugged in. Long blinks are 10, short blinks are 1. See if you can read them again. What do you mean, they can't check it at your local shop?
this happened to me once before
but i have to push the pin (hair pin.wires or whatever u are using)all the way in the connector.
and finally it worked for me.
Re: honda crx delsol - ENGINE CHECK CODES (hatchling37)
OK But when the codes just keeps on repeating itself how do I know when it stops and starts the new process? I was counting the flashes, they were all short blinks.
what does this mean?
please help.
cheers
dave
please help.
cheers
dave
frist of all.it will flash one sec at time.that means it is 10 counts.and the after the long flashing.it will have short flashing half sec a count.
just count how many long flashes and plus short flashes
and that will be your code error
