honda civic turbo injector no 4 fault
HI I NEED HELP MY 99 CIVIC TURBO SI GOT NEW 360CC INJECTORS AND RESISTOR BOX AND CHIPPED OBD1 P06 ECU AND HAS BEEN WORKING FINE, UNTILL THE ENGINE CHECK LIGHT CAME ON AND FLASHED CODE 16 WHICH IS INJECTOR FAULT. I CHECKED ALL INJECTORS AND IT WAS NO 4 INJECTOR BUT THE INJECTOR IS FINE IT IS NOT GETTING ANY POWER SO ASSUMED IT WAS THE RESISTOR BOX THAT WAS THE PROBLEM, CHANGED IT STILL THE SAME PROBLEM, PLUGGED IN DIFERENT ECU,STILL THE SAME PROBLEM, CHASED EVERY WIRE FROM INJECTORS TO RESISTOR BOX TO ECU EVERYTHING IS FINE AND RECENTLY I HAVE CHECKED THE MAIN RELAY AND SEEMS TO BE FINE CAN ANYONE HELP ME PLEASE THE CAR ALSO WHEN DRIVING OK AFTER BOOST IT STARTS TO CHUG AND JUMP IN LOW REVS EG IN TRAFFIC BUT IF I TURN CAR OFF AN BACK ON IT STOPPS AND DRIVES FINE HEEEEEEEEEEEEELLLLLPPPPP
Re: honda civic turbo injector no 4 fault
THIS IS WEIRD! MY CAR IS DOING SAME THING!!!
So i took my car out of storage and drove it around a few times, everything seemed to be ok i decided not to boost until i put some fresh gas in the tank which i did.Then i hit it down a straightaway car cut off, i thought it turned off but it was still on car weent into some safety mode where it only revs up to 3500
i found the problem with the injector it was an ecu obd2 to obd1 jumper harness was faulty two wires were loose inside the plastic mould hope this helps you
mickey b16
05-26-2009 04:02 PM
