HONDA CIVIC EX COLD AIR INTAKE QUESTION
Old 06-30-2006, 09:38 PM
jmoss1987's Avatar
Default HONDA CIVIC EX COLD AIR INTAKE QUESTION
My girlfriend has a 95 honda civic ex. She ordered a cold air intake off ebay and it got here yesterday. I have never put any intakes on except a short ram. I got to her house and I am clueless lol. There is a hole over on the left side. Does the pipe go down in the hole and then the filter doen by the fender? I am just lost on what to do. It came with 2 pieces. One is long and the other is like 6 or 7 inches long. Any help would be appreciated! Thanks
Old 06-30-2006, 10:03 PM
Turbo_y8's Avatar
Default Re: HONDA CIVIC EX COLD AIR INTAKE QUESTION (jmoss1987)
its not rocket science. Just look at the bends, what will work fromt he throttle body to the opening? I hope you know how to remove the bumper to remove the lower resonator
Old 06-30-2006, 10:09 PM
jmoss1987's Avatar
Default Re: HONDA CIVIC EX COLD AIR INTAKE QUESTION (Turbo_y8)
First of all, I don't know much about this stuff, so don't freakin act like I should. I wouldn't be asking if I did. What we ended up doing was just using the long piece. and not even using the shorter one. No, I don't know how to do what u said I should. Could u try to explain somewhat.
Old 06-30-2006, 10:14 PM
RBaluca.com's Avatar
That one piece should be attached to the throttle body. The other piece goes down into the bumper through the hole on the left. I think you can just remove the fender liner remove the lower res., and replace it with the lower pipe, then you should be able to stick on the filter.
Correct me if I'm wrong though.
JdelMsolG's Avatar
just take out the old factory intake box. then take out all the bolts that are in a straight line directley in front of the radiator and then get on the ground take off about 3 screws on the wheel well on both sides, and thats takes the front bumper off. Then on the right side of the car where the cold air filter will be placed there is a usually white piece of plastic that is a part of the factory intake system, its kind of a bitch to get out, just yank, hack blah blah do what you have to do to get it out just dont damage anything else while you're down there. after you get that out of the way, the long piece of pipe goes onto the throttle body, you'll have to figure out which way it goes, but it should line up with the whole where the resonator was. the small piece actually goes through the whole and should maybe bend alittle and the filter is put on there.
and since you dont know much about this kind of thing. alittle advice, stay away from ebay products, if you dont know much about them. and if you drive in the rain often you may want to buy a bypass valve so you dont suck up too much moisture, i think it cuts alittle on horsepower, but it'll save your *** down the road.
Old 06-30-2006, 10:16 PM
prison_snitch's Avatar
the second peice goes through the hole and the filter in behind the bumper. in order to do this you need to remove the bumper and take ou the resonator biox
Old 06-30-2006, 10:19 PM
jmoss1987's Avatar
Default Re: HONDA CIVIC EX COLD AIR INTAKE QUESTION (JdelMsolG)
Yea, she already has the bypass valve. She didnt pay much for the intake so she was wondering if she could just keep it like it is. I have the long piece on it and then the filter on that. The filter is sitting right above the hole. Will it be ok to leave it like that? The reason she got one is because she just got the car and it didnt have an intake on it at all. Thanks for the help.
Old 06-30-2006, 10:21 PM
Yeah it's fine to leave it that way if you want.
Old 06-30-2006, 10:23 PM
jmoss1987's Avatar
Default Re: (re-marquable)
Thank you so much for the help. She pretty much just wants to be able to drive it and her dad wouldnt let her until she got an intake on it and her new hood on it. I appreciate the help!
0319cicicEX
Engine Management and Tuning
02-18-2014 05:01 PM
wade9233
06-06-2013 01:35 PM
Xenon7
03-31-2012 09:15 PM
chinolal
09-22-2006 04:50 PM
civEX32
02-27-2006 06:14 PM
Quick Reply: HONDA CIVIC EX COLD AIR INTAKE QUESTION
