homemade stroker kit
Didn't know where the best place to post this was, but i'll try here. My buddy and I want to do our own stroker kit for his 2000 SI. We were going to use an LS crank...but we're unsure of what kind of rods and pistons would be good. We're trying to keep everything OEM Honda parts. Anyone have ideas/suggestions ?
Re: homemade stroker kit (MagillaGorilla)
well, the thought crosseed my mind to put the LS crank, rods, and 81mm JE higher compression postons in it, but, i don't think the LS rods will hold up too well. He already revs it to 9k, and has the capability of going to10,200 rpm, but he starts to lose power there.
Re: homemade stroker kit (HXMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HXMan »</TD></TR><TR><TD CLASS="quote">You probably can use an LS crank...but as far as I know there are no honda rods that will be the right length for you.</TD></TR></TABLE>
What if he where to use stock Si crank, but b20 rods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagillaGorilla »</TD></TR><TR><TD CLASS="quote">
What if he where to use stock Si crank, but b20 rods. </TD></TR></TABLE>
that would for sure raise compression, but would it really change the stroke, since he wouldn't really extend the stroke by using the stock crank?
1 Post
Re: stroking b16 (MagillaGorilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagillaGorilla »</TD></TR><TR><TD CLASS="quote">No, because the b16 is smaller, and with the pistons going up higher, it would create more compression.</TD></TR></TABLE>
Exactly. With the pistons going up higher, you're decreasing the displacement, not increasing.
Re: stroking b16 (fowleryo)
Yea on me. Ok your makin compression; losing displacement.
Hehe, thx for catching m slip.
EDIT- You would still be stroking the motor, but you will lose displacement. But that sounds funny, lol.
EDIT #2- I meant stroking as increasing how high the pistons go, but you loose displacement due to the b16 hehe
Modified by MagillaGorilla at 7:45 PM 7/20/2003
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagillaGorilla »</TD></TR><TR><TD CLASS="quote">EDIT- You would still be stroking the motor, but you will lose displacement. But that sounds funny, lol. </TD></TR></TABLE>
Actually, you'd be destroking the motor.
Stroking = gaining displacement
Destroking = losing displacement
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagillaGorilla »</TD></TR><TR><TD CLASS="quote">Ok now i got it, with the b16 block you are destroking it but making compression.
Thx for helping em under stand this lol. </TD></TR></TABLE>hey chad, someone must have called the Slow Zone. "y0! Let m3 g3ts a Str0ka kit!"
Re: stroking b16 (EF9_SiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9_SiR »</TD></TR><TR><TD CLASS="quote">hey chad, someone must have called the Slow Zone. "y0! Let m3 g3ts a Str0ka kit!"</TD></TR></TABLE>
lol **** you man, im happy I finally figured it out.
Longer rods won't give you more displacement.
Displacement is stroke X bore.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MagillaGorilla »</TD></TR><TR><TD CLASS="quote">What about b20 connecting rods?</TD></TR></TABLE>
B20 rods are the same as LS rods. Identical. What makes the difference between the b20 and the LS is the the bore size. B20 has a 84mm while the LS is 81mm.
liam
liam
